The version of wdwebcamcapture.exe that comes
With WD install has not changed
Did you download instead from the download files folder
A new version of the webcam program?
If so…when did you download that?
Hi Brian. On February 14th I downloaded the zip version from the WD download page. Unzipped the folder. Copied the files that showed a “date modified” later than my last WD update and pasted the files into the Wdisplay folder.
I’ll re-download the latest Weather Display zip file and re-past the wdwebcamcapture file right now. Maybe the file got corrupted in the process on the 14th.
Thanks Brian. I downloaded and copied the file you suggested into the wdisplay folder and activated wdwebcamcapture.exe. The picture produced was blue again. I opened the wdwebcamcapture settings and went to the “capture Settings” tab. Although the “current video capture device and properties” said “Logitech Webcam C210” (the correct setting), I clicked on the list button and changed it to "ATI TV Wonder Contexant Capture). The picture remained blue. So I returned the “current video capture device and properties” to the correct settings AND THE PICTURE CAME ON!
IT’S FIXED 8O
