is anyone still using image salsa?
after using this software for many years, it now does not work.
each time i try to open it, it states that an instance of image salsa is already open.
i have tried to delete and download it again but still get the same problem.
anyone have similiar issues.
is there any other software that would work?
thanks
larry
you can do data overlay with WD’s web cam program
I’m running ImageSalsa 2.0.13 (beta) on my Win10-Pro system. I did have to mark the properties of the imagesalsa.exe to use Windows 7 compatibility mode to make it run correctly – doesn’t seem to like Win10 native mode. Otherwise, it’s running fine.
Did ya check in task manager to make sure 2 wasnt running? also check services just in case…
Thanks for the replies.
after deleting the program and reloading several times,
it is again working. “for now”
Larry
