Try to use full path for $path_to_lastret like “/home/username/public_html/wxsim_ewn/wxsim/lastret.txt” or whatever the beginning is on your server. data.php runs “stand-alone” so full path is the easiest way here.
x.php shows anyway that it parses the data OK and there are no problems with the PHP itself.
Thanks, Henkka! Finally it’s working. I have a test site here: http://runarweb.com/forecast_test.php It was the path that was the problem. You were right that I needed an absolute path for $path_to_lastret and $path_to_langfiles. They are now:
After looking at it looks great. But I have some comments and questions:
In the Graphs section it’s difficult to see the precipitation amount when it rains several hours. The numbers overlap. Also there is no Y-axis for precipitation. Have you done any thinking about that?
Would it be possible to have the days at the X-axis, not only the time? It would make it easier to get an overview of each day.
I don’t quite get how the buttons on the bottom of the graps work? When I enter Graphs, Forecastgraph is marked and the graph is shown. Pressing Show whole forecastperiod shows that graph, but now both buttons are marked. Pressing Forecastgraph now nothing happens. Pressing Show whole forecastperiod switches between the 2 graph each second time.
Legends for Dewpoint and Feels Like are greyed out. Do you plan to show them?
Do you mean this to be a replacement for the 3-in-1 script? I don’t see 3-in-1 on your site anymore.
In the Graphs section it's difficult to see the precipitation amount when it rains several hours. The numbers overlap. Also there is no Y-axis for precipitation. Have you done any thinking about that?
I know that. The “full” graph are not that good, i did the graph initially as daily as it gives more width per timestep and also fits better on narrow screens. Whole “EWN-forecast” design was made with mobile screens in mind.
It would if the days fits. The problem are narrow screens and how to (auto)detect if days fits or not
I don't quite get how the buttons on the bottom of the graps work? When I enter Graphs, Forecastgraph is marked and the graph is shown. Pressing Show whole forecastperiod shows that graph, but now both buttons are marked. Pressing Forecastgraph now nothing happens. Pressing Show whole forecastperiod switches between the 2 graph each second time.
The left button are actually a leftover from the orginal and could be removed from the WXSIM-version as it do nothing.
I see you figured them out I left them hidden as default to keep the initial look clean.
Do you mean this to be a replacement for the 3-in-1 script? I don't see 3-in-1 on your site anymore.
Yes, i think so. Actually, my own WXSIM have had (and still have) problems with its accuracy with MAE’s well above 3C as worst, and it have came in mind a couple of times to scrape whole WXSIM from my site (and then discontinue my WXSIM-related scripts). So the interest about it haven’t been the best. But but…That haven’t happen yet
Hi guys,
i’ve an issue with main icon on wxsim ewn style script.
Main icon shows sunny with patches of fog but details icon shows rain.
The correct icon is rain because in lastret/plaintext there are amount of rain forecasted.
Sorry I must say I had a working forecast right from the box ! Only updatetime did not work.
Changed the whole paths to the (lastret)/datafiles and everything was oke.
Till I restarted the browser: no forecast(s) what ever I tried. Cookies?, settings?. Did a whole new instalation, suggestions here on the forum, etc but no luck
It seems that “nordicweather.net” is down.
As a result I just realised that my “wxsim_2017.css” was referencing “//static.nordicweather.net/fonts/” so the icons do not display.
I already had the “//mylocalwebsite/wxsim/fonts/ubuntu*” files so just referenced them to local and then downloaded the :
Weather Icons 2.0.8
Updated September 19, 2015
Maintained at http://erikflowers.github.io/weather-icons
and did same with them “//mylocalwebsite/wxsim/fonts/weathericons-regular-webfont” all works fine now, I noticed many other users have not done this, so just a heads up.
Kind Regards,
As I have no live website, just thought I would share my mods.
WXSIM “EWN-style” incorporated into Meteotemplate as a Block as i have to use Lastret.txt due to DST issues with Latest.csv.
Image 1: More Button closed
Image 2: More Button open
Thanks Henkka and Jachym.
regards,
I have used one of my standard templates and just used include (‘wxsim/forecast.php’); in order to ensure the paths are correct (all my web page address are in the root folder).
I’m guessing its a template issue, but I cant work out why it is doing this?
By using that stand-alone script inside your template page there are two sets of head and body definitions.
You can check yourself by (example with Chrome browser) right-click select show source.
This is the end of your menu html directly followed by an extra <html head and body tags.
</div><!-- end leftSidebar -->
</div><!-- end doNotPrint -->
<!-- end of menubar -->
<!DOCTYPE HTML>
<html><head>
<meta name="viewport" content="width=device-width, initial-scale=1.0">
<link href="//maxcdn.bootstrapcdn.com/font-awesome/4.7.0/css/font-awesome.min.css" rel="stylesheet"/>
<link href="//static.nordicweather.net/css/leaflet-0.7.3.min.css" rel="stylesheet"/>
<link href="//static.nordicweather.net/css/bootstrap_ewn.css?2017.03" rel="stylesheet"/>
<link rel="stylesheet" href="css/wxsim_2017.css?2017.03" />
<link rel="stylesheet" href="css/weather-icons.min.css?2017.03" /> <style>
body {background: #fff;color: #555555;font-family: "Ubuntu","Lucida Grande",Verdana,Helvetica,sans-serif;font-size: 13px;font-weight:300;line-height:1.25em;margin:0}
:focus {outline:0}
I think for less a browser is confused and does not know what you want.
Solution:
Us an iFrame and use this url http://www.bearsbythesea.co.uk/wxsim/forecast.php as the link in the iframe.
Than both your saratoga page and the wxsim page are handled indepently and both will display correctly.
P.S. The blank lines come from this directive somewhere in the EWN code
<div style="clear:both"></div>
If used inside a template page it forces the remaining html to start below the menu.
It should read
<div style="clear:right"></div>
when used in a Saratoga template.
But as I do not have the script itself, I do not know where that html code is located.
And there can be multiple other influences between Saratoga CSS and EWN css, Better use an iframe in these cases.
hi
I’ve a problem about transltaion from english to italian.
I’ve tried many settings but teh problem persists.
I’m using PHP 5.6.3
Below is reported a part of config.php
Have you any ideas
Thanks in advance
$wxsimlocation = "Genova Molassana"; # Your location
$latitude = 44.46;
$longitude = 8.97;
$tzabb = "Europe/Rome";
$datestyle = "d.m.Y";
$timeFormat = "d.m.Y H:i"; # Timeformat
$updatehrs = array(3,5,8,11,14,17,20); # Hours when wxsim runs
$updateminute = 47; # minutes past full hour for upload time
$jqueryload = true; # Should we load JQuery? (Set to false if your site loads it by default)
$bootstrapload = true; # Should we load Bootstrap? (Set to false if your site loads it by default)
$mainwidth = "100%"; // Use 100% for responsivity
I’ve solved the previous problem (added $lang=“it”; into the config.php ) but now have a new problem about precipitation.
Forecast precipitation for Wednesday is over 60mm but no value appears (NaN) and no mention is reported into the description section. (see attachment).
Have you any suggestion?
Thanks in advance
Afasol3
