Hi folks, everything is working well with wd, but the webpage is not uploading/displaying correctly. The only way to upload correctly would be to do it manually. I also noticed that the only webpage that is uploading the correct time stamp is the crater lake template.
OK fixed!! All it took is those five little letters (index) to fix both problems!! Now I have lots of refining to do.
I’m finally back after quite some time of no WD. Unfortunately, I had to completely uninstall WD do to myself modifying/exploring WD
that led to a complete scramble of data, instability, and a main WD screenshot that was so hosed up that I spent hours trying to correct! And Just when I thought I fixed the problems, they all came back after restarting WD.
All I can say is the support form this forum is top notch!! The WD program has more bells, and whistles than any other program out there!!
However, for me it’s a bit complex, and trying new things can lead to a disaster. #-o It’s working good now, so I think I’ll leave it alone!!
Thanks Brian, data backup is set to on. All is working great with the Crater Lake style Web site template. However, I’m unable to retrieve the the averages/extreme month data in the jump box. However, when I set up the generic style web site ( by turning off the override toggle switch/un-tick crater lake style web site) I’m able to view this data.
The HTML script looks like this on the mywebpagetemplate:Select averages/extreme month
February 2017
Fixed Brian!! I only spent hours trying to figure out what was wrong!! I ended up comparing the standard HTML Webpage template script to the Crater Lake template (The standard uploaded and was viewable, the Crater Lake wasn’t).
Here is the HTML template that worked:
Select averages/extreme month February 2017
Here is the HTML template that didn’t work: :x
Can anybody see the difference?? What a pain in the A$$ this was!!
Ok Brian all is complete, including the website, and registeration. However, the only thing that is weird is the “setup” box in the WD taskbar is unselectable (not bold set). I restarted WD but to no avail.
