Hello, my gustdial hand does not follow the numbers. I attach an example. Last version of WD in use.
Thanks for the attention
giordolo
what windspeed unit in use?
try a new .zip update, should be OK now
Very well done Brian, many thanks.
Still 1 question: are you sure that your last version is still producing the uvdial.gif? i don’t have it updated since a lot of time. And it has also transparent backgroud, so is different to the rest. Please could you have a check? (maybe I simply missed some config parameters but I’m going crazy)
Thanks again
uvdial.gif is updated here OK in the webfiles folder in testing.
check that file modified time/date file stamp?
I’m sorry but it seems not working fine.
check here wind http://www.zzzzz.net/meteo/VirtualWeather/dettagli/gustdial.gif
it is not in sync
I see you have set for it to be an animated gif
I had not tested that
that will be the issue
if you unset for it to be an animated individual dial images, as a test, then it should match up?
Hello how can I do to set that?
anyway I prefer to have it as animated
I will see if I can get the animation working correctly and let you know
I have fixed this now (and the problem with the individual dial images)
the problem turned out to be that the gauges were set to have the needle animated
use a new .zip update of WD
Very well done, solved!
was a bit of a head scratcher
