Hello
I get this following message while wxsim process is running. Can you tell me what happens ?
Thanks in advance
Cheers
Isabelle
Hello
Thanks in advance
Cheers
Isabelle
Hi Isabelle,
I found the problem, and have emailed you about it. Meanwhile, I’ll share what it was with the group:
Look at ths RAOB data. The first one (for Payernne 06610) has more slashes (missing data) than I’ve seen before, and more than WXSIM could handle!
TTAA 04111 06610
99/// ///// ///// 00042 ///// ///// 92668 00400 17002
85348 00002 20515 70877 09509 23025 50539 27559 23532
40696 38985 23033 30888 49981 23024 25006 54780 24527
20149 56179 25025 15334 56379 25015 10591 58178 28015
88233 55979 24524
77394 22535 41414
77192 26033 42437
TTAA 04121 10739
99965 06041 15003 00026 ///// ///// 92667 05458 14512
85354 01657 15013 70887 09724 18510 50541 25135 20517
40700 37344 21522 30891 53945 23026 25007 59762 23530
20147 52781 25018 15331 52982 25517 10589 60378 26513
88252 59762 23531 88109 59779 25512
77260 23032 40714
31313 48108 81045=
I’ve just made a change so that WXSIM will now make an “educated guess” about what should go there. It’s not perfectly accurate, and may alter the early part of the forecast a bit, but it should avoid the error. To fix this, get these two files:
and use them to replace the ones you already have. Then try a forecast again. This should avoid the error.
Tom
Hi Tom,
Great of you. It seems to work asap
You’re the best
Cheers, :lol:
