Sometimes a minimum temperature (or maximum) is reached during an interval in the middle of a minute but if this temperature is not in the beginning of the next minute it’s not saved to logfiles or datafiles.
For example: At 7:15:00 is 13.2
I think yes I can improve this situation
I will look into this
Ok. Thanks.
I have implemented this in build 42 zip update
Thanks. I’ll try it
Well I’m testing this fix and works great in temperature and humidity (no inconsistencies between daily-monthly-yearly max/min values) but I’ve noticed that in pressure is still doing the same.
Was pressure fixed too ??
no, but, the pressure reading is not any faster than 1 minute, so it should not be affected I would have thought
Yes, it is affected. Pressure update interval in VP2 is less than 1 minute and in pressure peaks sometimes those inconsistences appear.
