Build 10.37S41 not retrieving data from Data Logger on start up
Good morning,
I am running Weather Display build 10.37S41. After a reinstall, it has stopped retrieving data from the previous time that the program was switched off, but it happily receives current data. I have a Davis Vantage Vue station.
If I try and download data from a previous time, that doesn’t work either. Can anyone help me, please?.
Thank you.
Very Best Wishes,
Bob.
is the switch on under control panel, data logger setup?
what shows under view, debug info, after start up?
As this? If so, yes it was.
Hello Brian,
It says "Doing checking of time zone calculation
Daylight saving not in use
Loaded all time records
connected OK to com port 3
restarting timer
*sending DMPAFT
Asking for archived data download
Davis VP Retrieving data from: day 2 month 2 year 2017
Retrieving data from: hour 7 minute 15
ask for time/date of record…
1 6 1
1 1 2
1 2 3
1 3 4
1 0 5
1 77 6
1 135 7
Sending OK…
Aborted
All data downloaded or did not sync correct!
formating the VP data
vp data read in 1
Weather station type number 31
Reset overnight minimum temp 21:00:00 February/02/2017
Reset overnight minimum temp 21:01:00 February/02/2017
Normal daily resetting wind/temperature daily value , day: 3
Normal daily resetting rain daily value , day: 3 rain today 0.0 mm
Reset overnight minimum temp 21:00:00 February/03/2017
Reset overnight minimum temp 21:01:00 February/03/2017
Normal daily resetting wind/temperature daily value , day: 4
Normal daily resetting rain daily value , day: 4 rain today 1.3 mm
Hello, it’s playing up again…
restarting timer
*sending DMPAFT
Davis VP Retrieving data from: day 9 month 2 year 2017
Retrieving data from: hour 15 minute 10
1 68 1
Aborted
vp data read in 1
Daylight saving not in use"
what data logger type?
It’s a Davis Revision B data logger.
what I mean
is it usb or serial or IP ?
It’s a Silicon Labs CP210x USB to UART Bridge (COM3)
OK, its a USB data logger
what you could try, which has worked for others, is power down the console
remove the data logger for 5 minutes
replace, power up console, set the correct time and data logger interval (1 minute)
then wait for data to build up and then run WD and see if the data download works
Bristolian,
Did you perform any firmware updates to your console?
