Hi guys,
this morning i’ve tried this error:
I’ve red previous posts but i’ve no idea how to fix this.
I’ve also tried to renamed latest.wxf file but this error come back.
Thanks in advace for your help.
Alessandro
latest.wxf.txt (166 KB)
Hi Alessandro,
Thanks for that file! I’ll check it out to try to find the problem. What version of WXSIM were you using?
Tom
Actually, that .wxf file is fine. Based on the error message, I now think retini.txt might be damaged. The good thing is that you should also have a file called retinibak.txt, which should contain your last succesful copy of retini.txt. Try opening that and then saving a copy as retini.txt. That might fix it. Let me know!
Tom
sorry to bump this up !
latest.wxf error line 1909
removed latest.wxf no solution
then renamed retinibak.txt to retini.txt and run wixsim/wxsimate/wret.exe again
no solution
btw: is there a program where to see the line counts ? no idea were 1909 is
thanks so far
(upload wxf file not allowed ; howto ? )
I use Notepad++. It’s an excellent replacement for Windows Notepad and has a lot more functionality, including displaying line numbers.
Ah notepad !?
Thanks for this !
latest.txt (149.2 KB)
first time renaming to bigg !!?? now success (thanks admin)
anyway notepad++ with linecounts but not any clue whats wrong
oops original topic name was error 1939 (and mine 1909 but same issue I suppose)
I don’t know the structure of the file, but comparing the block of data (12:00z?) including line 1909 with the previous block (11:30z?) shows the same structure, same number of fields and similar values.
I think you might need Tom to offer some advice on this. I know he’s around at the moment but doesn’t visit the forum too often so it might be best if you send him an email.
Thanks for advice !
I send an email to Tom 2 days ago and I’m waiting for his reply
I did all exe files manually, that runs well now by daytime.
Somewhere the error is by night after running latest sim/simate at 23.00h
Fingers crossed meanwhile
