Some of my visitors at my site has noticed that the %changeindaydec% is a bit wrong - and I have recalculated it and they seems to be right about 6 minutes today (January 31 2017)
%changeindaydec% = +01:33
Shortes day in December was December 21 2016:
Sun up: 08:53
Sun down: 15:47
Day lenght: 06:54
Today (January 31 2017):
Sun up: 08:19
Sun down: 16:52
Day lenght: 08:33
Difference between 08:33 and 06:54 is +01:39 and WD tag %changeindaydec% = +01:33
I have now had a new go for the latest WD version (build 42) and WD e-mail reports are still not working with my setup. Build 34 is working perfect.
In ftpfulllog.txt I see this:
Port 25:
*******warning email send********
Connecting to mail server.
[10060] Connection timed out
Failed to connect: [10060] Connection timed out
File not found c:\wdisplay\webfiles\reportweek.txt
Time of Weather report: 12:12:49 Date of report: 25-02-2017
File to attach is: C:\Vejr\Webcam\webcambillede.jpg
Sending email to server 64.233.164.108
10060: [10060] Connection timed out
Port 465:
OK
Connected.
OK
Disconnected.
Time of Weather report: 12:14:13 Date of report: 25-02-2017
Sending email to server 173.194.222.108
301: Interrupted.
Port 587 (Works with build 34):
OK
Connected.
220 smtp.gmail.com ESMTP o5sm2593018lfo.35 - gsmtp
EHLO VEJR-PC
250-smtp.gmail.com at your service, [xx.xx.xx.xx IP adress hidden by me]
250-SIZE 35882577
250-8BITMIME
250-STARTTLS
250-ENHANCEDSTATUSCODES
250-PIPELINING
250-CHUNKING
250 SMTPUTF8
AUTH LOGIN
530 5.7.0 Must issue a STARTTLS command first. o5sm2593018lfo.35 - gsmtp
Time of Weather report: 12:15:06 Date of report: 25-02-2017
Sending email to server 64.233.162.108
161: SMTP protocol error. 530 5.7.0 Must issue a STARTTLS command first. o5sm2593018lfo.35 - gsmtp.
Im using Gmail as e-mail.
I have also tried ticking/unticking “Use with SSL e.g. smtp.gmail.com”
I tried upgrading to latest build 44 and %changeindaydec% is still 5-7 minutes off.
I have doubble checked the coordinates in the Sun/moon setup and they are correct.
N56 10’58
E9 30’26
%changeindaydec% says +05.11 - but the correct is +05.18. Right now the 5-7 minutes dosent mean much - but in late December and January/Febuary 5-7 minutes give a lot in difference.
