Not sure when this started by my 24/72/Month graphs are not uploading. I can got and to the create/upload manually in the Internet files page but it will not upload by itself. Times are set for both creation and upload. Ideas?
are you using the customise internet and file creation override do you mean?
and are you refering to the curr24hourgraph.gif etc graphs?
Internet File Creation & Upload > Setup Page #1 > curr 24/48/72 hr graphs
are the files being created OK in the WD webfiles folder?
thats the first thing to check
Yes, the files are being updated in the webfiles folder. They are not being uploaded to my website.
any errors under view program event lot, in WD?
and you are sure you have set times to upload for those files and the switch is on in the upload times?
do other files upload OK?
what shows in the ftplogfull.txt file?
maybe try setting the times to upload different to other files upload times?
Everything looked good. Even the ftplogfull.txt showed the file was being uploaded but it never changed on the server. I set the creation time to every 5 minutes and set the upload time one minute after that. The file is now uploading properly so everything is OK.
I wonder before if the file was being uploaded (so it was locked) when WD was trying to create it so it never got created?
