I started to use some Metar data for my weather station. Had a question if rain data comes from the Metar that I’m using; KCCR in Concord,CA? I have WD setup to update my raindata gif to use on my web page but it appears that it isn’t being updated; does the gif just get updated when there is rain data?
Would use my own rain data but Bloomsky hasn’t updated the API yet for there storm data.
Brain-
Ok, the metar that I’m using for rain data; does in effect send rain data.
I have file #37 Raindata.gif setup to be created and uploaded along with the detail graph checked. If I manually upload the file everything works; but it isn’t uploading automatically. I checked and both of the switches are turned “on” and the create times and upload times are set.
so the main internet switch is on and the customise override swith is on?
and you have it setup in the bloomsky setup to use the data for WD data?
(WD will only be getting temp/hum data at this stage)
setting the station type as stationless works here for creating and uploading a file (eg rain detail) when also set in the bloom sky setup to use the data for WD data
Just downloaded the update. When I go to the movie “tab” click “enabled”. Then when I hit “Play Latest” the movie box flashes and then stays black. I checked the web portal for my Bloomsky and there is a movie from yesterday.
