Just a thought that would be nice. Is it possible to add wxsim forecast to main page of weather display. I think it would be useful. Just thinking out loud.
Regards
Guru
Regards
Guru
do you mean a web page main page or the main WD screen?
you can add custom tags to WD main screen
and there are custom tags for the forecast tags
if you set up WD 5 day forecast…do that in the noaa forecast download, select a 5 day forecast to use
and then click on the main screen icon to bring up the 5 day forecast…and there you can select thats its a wxsim file in use
(from memory)
Yes, I meant the main WD screen.
I have had a play following your instructions but couldn’t get it to work. I presume I had the right wxsim file selected (latest.txt) but getting it to the main screen ??
Regards
Guru
