Hi all,
I wish to set up my own monthly detailed climate report but Im not quite sure how to and what tags I can use if they are available. Can someone point me in the right direction please? The attachement is an example of the columns & headers I wish to use. Would appreciate any advice.
there are these, in the tagslist.txt :
Detailed climate data extra tags
%slr1%…Max Solar for day 1
%slr2%…Max Solar for day 2 (repeat up to day 31)
%suv1%…Max UV for day 1
%suv2%…Max UV for day 2 (repeat up to day 31)
%slrp1%…Total Solar power for day 1 (kwh)
%slrp2%…Total Solar for day 2 (repeat up to day 31) (kwh)
%ht1%…Max Heat Index for the day (repeat up to day 31)
%wc1%…Min windchill for the day (repeat up to day 31)
%set1%…Daily ET for day 1
%set2%…Daily ET for day 2 (repeat up to day 31)
%soilh1%…max soil temperature for day
%soilh2%…max soil temperature for day (repeat up to day 31)
%soill1%…min soil temperature for day
%soill2%…min soil temperature for day (repeat up to day 31)
%wover13%…number of days the max windspeed for the day was over 13 knots
%wover17%…number of days the max windspeed for the day was over 17 knots
%wover21%…number of days the max windspeed for the day was over 21 knots
%hm1%…Max hum day 1 (change day number)
%hmn1%…Min hum day 1 (change day number)
I just wanted to see if I can create a report to help automate the one that I current fill in manually (using excel) from the various pages in the program. I seem to be a bit out of my depth at the moment. Might need to revisit it again in the future.
Just to clarify further before revisiting it at a later date (lots of learning to do). I wish to create a report with the fields in it (same order) that I have in the attachment I posted to help automate the process I currently do manually. Thanks for the advice so far.
You can add the tags in my first reply
To the climatedata.html in the WD web files folder
There are some already available templates with e.g solar and humidity data
I have tried setting up the wddatabase with no luck. Using windows 10 & access 2016. Is it possible to change the way the daily logfiles are created? i.e Day,month, year as date and min & sec as time etc.
