Author Topic: Weather Warning e-mails not being sent  (Read 367 times)
Offline neildockar
  • Crondall Weather
  • Still a classic - like so many of us....
  • Crondall - UK
  • Chrome 55.0.2883.87
    • Crondall Weather
« on: January 11, 2017, 07:53:31 AM »
The weather alert "message" flashes up on my PC as normal (and I can see the yellow triangle flash up in the icon bar), but the e-mail is not then being sent to the distribution list.
When I try to send just the test to me, again the alert flashes up, but no e-mail is sent.
Not sure when this stopped working - think it was OK up to Build35, currently using Build39
Appreciate some help on this
Many thanks
Neil
Bashy
  • Guest
Re: Weather Warning e-mails not being sent
« Reply #1 on: January 11, 2017, 08:09:39 AM »
Just checked it for you, triangle shows for a second or 2, no email sent, even turned on to send just to me and still not sent
Thats with build 37
Online Weather Display
  • Davis VP2
    • Weather Display
« Reply #2 on: January 11, 2017, 05:39:03 PM »
the version of wdwarningemail.exe has not changed since 12 dec
but the problem might be to with the implicit/explicit ssl setting
what shows in the sentwarningemail.txt file
(just saying it does not work does not actually help)
also try this update, where I have changed that above setting
http://www.weather-display.com/downloadfiles/wdwarningemail.zip
Offline neildockar
  • Crondall Weather
  • Crondall - UK
    • Crondall Weather
« Reply #3 on: January 11, 2017, 05:46:17 PM »
Thanks Brian,
I'll download the update now.
In the meantime here's the file text:
*******warning email send********
Connecting to server 79.170.44.45
Connecting to mail server.
Attempting to connect to server.
OK
Socket connection established.
Starting secure channel handshake.
Enabling TLS versions: TLS1.2 TLS1.1 TLS1.0
Cipher Suites:
    TLS_RSA_WITH_AES_128_CBC_SHA256 (0x003c);
    TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384 (0xc02c);
    TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256 (0xc02b);
    TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384 (0xc030);
    TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256 (0xc02f);
    TLS_DHE_RSA_WITH_AES_256_GCM_SHA384 (0x009f);
    TLS_DHE_RSA_WITH_AES_128_GCM_SHA256 (0x009e);
    TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA384 (0xc024);
    TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA256 (0xc023);
    TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384 (0xc028);
    TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256 (0xc027);
    TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA (0xc00a);
    TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA (0xc009);
    TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA (0xc014);
    TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA (0xc013);
    TLS_DHE_RSA_WITH_AES_256_CBC_SHA (0x0039);
    TLS_DHE_RSA_WITH_AES_128_CBC_SHA (0x0033);
    TLS_RSA_WITH_AES_256_GCM_SHA384 (0x009d);
    TLS_RSA_WITH_AES_128_GCM_SHA256 (0x009c);
    TLS_RSA_WITH_AES_256_CBC_SHA256 (0x003d);
    TLS_RSA_WITH_AES_256_CBC_SHA (0x0035);
    TLS_RSA_WITH_AES_128_CBC_SHA (0x002f);
    TLS_RSA_WITH_3DES_EDE_CBC_SHA (0x000a);
    TLS_DHE_DSS_WITH_AES_256_CBC_SHA256 (0x006a);
    TLS_DHE_DSS_WITH_AES_128_CBC_SHA256 (0x0040);
    TLS_DHE_DSS_WITH_AES_256_CBC_SHA (0x0038);
    TLS_DHE_DSS_WITH_AES_128_CBC_SHA (0x0032);
    TLS_DHE_DSS_WITH_3DES_EDE_CBC_SHA (0x0013);
    TLS_RSA_WITH_RC4_128_SHA (0x0005)
Sending 189 bytes of handshake data.
Receiving 32 bytes of handshake data.
error during handshake[2]: 0x80090308
Failed to connect: error during handshake[2]: 0x80090308
OK
OK
Disconnected.
276: error during handshake[2]: 0x80090308
******WEATHER WARNING TEST !******
******THIS IS A TEST !******
Time of event was : 07:46 am
Date of event was : 11/January/2017
Current conditions :
Windspeed             4.4 mph
Direction              W  262
Temperature           9.6 C
Humidity              92 %
Barometer             1007.9 mb
Maximum windspeed     20.0 mph   W at time: 5:24 AM
Maximum speed last hr 18.0 mph  W at time: 6:55AM
Rain today            0.0 mm
Monthly today            22.0 mm
Maximum temperature   9.7 C at time: 5:44 AM
Minimum temperature   7.0 C at time: 1:06 AM
Rain Rate/min         0.00 mm/min (0.00 mm/hr)
Rain last hr          0.0 mm
Please note: This test is in english by defualt. The auto generated report will be in the language you have selected
  • Davis VP2
    • Weather Display
« Reply #4 on: January 11, 2017, 06:03:10 PM »
Quote
what port number do you have in use
see if the latest version fixes this error
Offline neildockar
  • Crondall Weather
  • Crondall - UK
    • Crondall Weather
« Reply #5 on: January 11, 2017, 06:07:42 PM »
My port number is COM 3
and just re ran the test with the new file - same result I think:
OK
Cipher Suites:
OK
OK
Disconnected.
Time of event was : 05:52 pm
Windspeed             4.3 mph
Direction            WNW  285
Temperature           5.4 C
Humidity              75 %
Barometer             1014.2 mb
Maximum windspeed     27.0 mph  NW at time: 10:36 AM
Maximum speed last hr 15.0 mph  NW at time: 5:02PM
Rain today            0.0 mm
Maximum temperature   10.8 C at time: 11:23 AM
Minimum temperature   5.4 C at time: 5:51 PM
Rain last hr          0.0 mm
  • Davis VP2
    • Weather Display
« Reply #6 on: January 11, 2017, 06:22:50 PM »
only really need to see the error part of the log
and the port number I mean is the port number in the email setup
Offline neildockar
  • Crondall Weather
  • Crondall - UK
    • Crondall Weather
« Reply #7 on: January 11, 2017, 06:29:14 PM »
Sorry Brian - it's Port25
  • Davis VP2
    • Weather Display
« Reply #8 on: January 11, 2017, 06:33:22 PM »
try setting the port to what is needed for authenticated email
(e.g what you have set for sending emails with your normal email client)
Offline neildockar
  • Crondall Weather
  • Crondall - UK
    • Crondall Weather
« Reply #9 on: January 11, 2017, 06:40:51 PM »
25 is also the default for my regular email
  • Davis VP2
    • Weather Display
« Reply #10 on: January 11, 2017, 06:43:22 PM »
if you could email me or PM me your email settings
then I will test/check here to see what I need to tweak in the program to get it to work for your email provider
Offline neildockar
  • Crondall Weather
  • Crondall - UK
    • Crondall Weather
« Reply #11 on: January 11, 2017, 06:51:34 PM »
Thanks Brian - just e-mailed to you now
  • Davis VP2
    • Weather Display
« Reply #12 on: January 11, 2017, 07:00:26 PM »
set the port to 465 and it will work
Offline neildockar
  • Crondall Weather
  • Crondall - UK
    • Crondall Weather
« Reply #13 on: January 11, 2017, 07:45:05 PM »
Perfect - thanks again Brian.
With exciting weather due here over the next 24 hours it will be tested for real  :D
