Weather-Display V10.37S b39
Weather Station - Davis VP2 Plus
O/S - Windows 10
Two issues are: No# 1 Averages/Extremes Reports - Detailed Climate Report is just a white blank.
No# 2 Weather-Display data (Not Current), Age: 149872:47:37, last update showing 11/30/99 12:00am
for #1
make sure that the climatedata.html file in the web files folder is OK…if not , replace that with the file that comes in WD
#2, that is on a web page?..url?
climatedata.html file is fine. another problem i discovered is that the testtags.php is blank. none of these problems didn’t happened until after i updated to b39. pasted b38 weatherdisplay.exe over b39 and it showed testtags.php once and then went back to blank. :?
any error under view, program event log?
i have tested here , no problems , latest version
when you say blank,do you mean like empty, or no data (i.e only – where data should be), or?
does build 38 work or earlier?
I must have Gremlins in my system, strangest thing, I uninstalled and re-installed b36, b37, b38, and b39, and so far everything seems to be working.
Thanks Brian.
