Author Topic: added Bloomsky support  (Read 474 times)
Online Weather Display
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 55.0.2883.87
    • Weather Display
« on: December 26, 2016, 09:35:26 PM »
I can add support for Bloomsky..worked out how to do it, using the API (you do need to get your key from when you click on the developer link, bottom left, when you sign in to your account (and so you would enter that into the bloomsky setup in WD)
i.e to get the temperature, humidity, and raw web cam image :)
now that they have added windspeed, that data can be used too..so the bloomsky can be a source of data as a stand alone weather station
(but it only updates every 10 minutes?)
or you can just have it where the web cam image is used by WD..and the temperature..as say a custom tag..for interest...to add to WD
good idea?
« Last Edit: December 27, 2016, 01:45:55 AM by Weather Display »
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
Re: Bloomsky support
« Reply #1 on: December 26, 2016, 10:44:52 PM »
I have it working :)
Offline aardvark
  • Des Moines, Iowa
  • Des Moines, Iowa, USA
  • Mac OS X 10.12
  • Firefox 50.0
« Reply #2 on: December 26, 2016, 11:51:24 PM »
it is a good idea.
The second unit , The Storm, connects via an IP link.  the API isn't set up yet it seems.  However, it has wind, rain and direction oh and uv.
Davis VP2 Plus; 24h  FARS; Extra Temp Humid sensor (2); Extra Temp Station (2); Soil Moisture/Temp Station;Weatherlink IP;USB; MAC Sierra; Bloomsky Sky2 ; https://map.bloomsky.com/weather-stations/faBiuZWsnpW6n6il;
http://www.desmoinesweather.org
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #3 on: December 27, 2016, 01:38:07 AM »
have added support now for Bloomsky
to build 27 .zip update
 :wink:
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
Re: added Bloomsky support
« Reply #4 on: December 28, 2016, 09:16:32 AM »
have added this same support to the Mac version now (was not easy)
Offline Fox_Of_The_Wind
  • Anthony
  • C:\DOS C:\DOS\RUN RUN\DOS\RUN
  • De Soto Wisconsin USA
  • Win NT 10.0
  • Firefox 50.0
    • De Soto Valley Weather
« Reply #5 on: December 29, 2016, 02:46:41 AM »
I was unable to get the bloomsky to work with my test computer. It might have something to do with that it could be because it it still running under windows XP? Anyway here is the error in the window that it gave me
handshake[2]: 0x80090326
But I was able to get the bloomsky update to work with a computer running windows 10.
so it might just be that I have a computer that is just to darn old to run the bloomsky update. Or is my XP computer missing something?
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #6 on: December 29, 2016, 03:21:59 AM »
it uses https
and so its likely that something was not compatible with XP for the hand shaking with the secure server
XP is very old now
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #7 on: December 29, 2016, 07:03:06 PM »
in build 38 you  can now set the station type as Bloomsky
  • Anthony
  • Win NT 10.0
  • Firefox 50.0
« Reply #8 on: December 29, 2016, 08:43:27 PM »
Thank you for the info. That is what I thought also. I am going to have to break down and upgrade my wx computer away from windows XP. I just liked my LED signs and so far I can't fig out how to get them to work with anything newer then XP.  all well
thanks again
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #9 on: December 29, 2016, 11:22:09 PM »
do you mean you cant find a driver for the Led sign?
in windows 10 you can set to use a different driver (e.g the one you have now)..it might still work
  • Anthony
  • Win NT 10.0
  • Firefox 50.0
« Reply #10 on: December 30, 2016, 12:44:30 AM »
I don't belive its problems with the drivers. The WD that is on the windows 10 system don't seem to want to start the cronledsign.exe program. I have tried a reset and a reinstall  but no luck.  I can't tell if windows is blocking something or what
Any thoughts on it?
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #11 on: December 30, 2016, 01:04:45 AM »
if you manually run that, does it work?
  • Anthony
  • Win NT 10.0
  • Firefox 50.0
« Reply #12 on: December 30, 2016, 11:01:38 AM »
no it still don't run. makes me think that it might be more then just that program not running
