Build 279 stops every night just after midnight
Since going to B279 I have noticed every night it seems to stop working just after midnight.
Wd stays up. Log files not updating. Wdisiplay.ini seems to update
Program log has an access violation (least it did the first two nights when I checked program event log - forgot to just now) - attached.
the problem arises due to changes in the latest compiler
its going to be difficult to track down
I suspect its with the daily av/ext update
you could try un setting to have that updated, in the upload times, in the ftp/internet setup
Hey…
Thanks… went back to B274.
I will try to put 279 back and do that for you
So i’m doing the right thing to test for you. That is done here:
I have fixed this particular problem now in build 280
also you should notice that this version uses a bit less cpu?
Hi Brian WD Mac-b280 downloaded and install but WD says across the top 10.37Mac279.
I will give Mac b280 go and report back.
Thanks again
BTrip
Just downloaded it and installed it, will let you know.
Thanks again Brian. You really do a great job !!!
Mine shows as B280
Hi Brian. Using build 280 and I am getting random data spikes in outdoor temperature, barometer, wind gust and maximum wind average. At the same time that the wind and temp data spike high the indoor temperature goes low. I do not see this using the older builds, I was using build 24 prior to using build 274/280. Let me know if there is anything you would like me to check.
Paul
Here are a couple of screen shots of log files. Data files are affected too.
No issues overnight with B280
I also did not see the issues in log files that was reported
I have a RainWise cc3000 data logger, maybe it is confined to that product. Went back to build 24 for now.
Hi Brian no over night issues with Mac-B280, No issues with the log files.
Thanks Again
BTrip
@mfd38
do you have use CRC checked?
try ticking that if not
I did not have that option selected. I have selected that and will let you know.
Thanks Brian
With the Use CRC option checked, WD stops communicating with the cc3000. As soon as I uncheck it WD starts talking again with the data logger.
ah
well, we need to get sorted…
@mfd38
try another download
and post here the raw data that should show under view, debug info
This is with the latest build with Use CRC checked, and WD is not communicating with the data logger:
Loaded all time records
Loaded units
Comport open OK
connected OK to com port /dev/tty.usbserial-A8009JJS
2016/12/23 17:24:30, 37.8, 66,29.85,202,  0.0,  1.0,  0.00, 6.60, 5.39, 78.1,!716C
2016/12/23 17:24:31, 37.8, 66,29.85,202,  0.0,  1.0,  0.00, 6.60, 5.39, 78.1,!D432
2016/12/23 17:24:32, 37.8, 66,29.85,202,  0.0,  1.0,  0.00, 6.60, 5.39, 78.1,!2BF1
2016/12/23 17:24:33, 37.8, 66,29.85,202,  0.0,  1.0,  0.00, 6.60, 5.39, 78.1,!8EAF
rainwise data length threshold 90 actual length 342 raw
2016/12/23 17:24:34, 37.8, 66,29.85,202,  0.0,  1.0,  0.00, 6.60, 5.39, 78.1,!C456
rainwise data length threshold 90 actual length 84 raw
**formating rainwise data***
crc 31471 50262
crc fail part 2
Comport error 35: Resource temporarily unavailable
2016/12/23 17:24:35, 37.8, 66,29.85,202,  0.0,  1.0,  0.00, 6.60, 5.39, 78.1,!6108
crc 57265 24840
crc fail part 2
2016/12/23 17:24:36, 37.8, 66,29.85,202,  0.0,  1.0,  0.00, 6.60, 5.39, 78.1,!9ECB
For comparison, this is the latest build 280 without using the CRC Check, and WD communicates ok:
Loaded units
Comport open OK
2016/12/23 17:27:37, 37.7, 66,29.85,202,  0.0,  1.0,  0.00, 6.57, 5.39, 78.2,!D172
2016/12/23 17:27:38, 37.7, 66,29.85,202,  0.0,  1.0,  0.00, 6.57, 5.39, 78.2,!E1DE
2016/12/23 17:27:39, 37.7, 66,29.85,202,  0.0,  1.0,  0.00, 6.57, 5.39, 78.1,!11D3
2016/12/23 17:27:40, 37.7, 66,29.85,202,  0.0,  1.0,  0.00, 6.57, 5.39, 78.1,!DE56
2016/12/23 17:27:41, 37.7, 66,29.85,202,  0.0,  1.0,  0.00, 6.57, 5.39, 78.2,!2E5B
1
2016/12/2317:27:41
2 37.7
3 66
4 29.85
5 202
6 0.0
7 1.0
8 0.00
9 6.57
10 5.39
11 78.2
12 !2E5B
2016/12/23 17:27:42, 37.7, 66,29.85,202,  0.0,  1.0,  0.00, 6.57, 5.39, 78.2,!D198
1
2016/12/2317:27:42
2 37.7
3 66
