Option to stop creating clientraw.txt
Hello
I’m creating a customclientraw file every 4 seconds (it’s set to 2 seconds in update frequency but actually is generated every 4 seconds).
Is there any option to stop creating clientraw.txt every 3 seconds just to stop stressing CPU generating a file that I don’t use at all in realtime??
Something like including a “not create clientraw.txt realtime” tick option??
I think CPU and WD wouldn’t be so stressed generating those two files almost at the same time.
I could add that option…yes
but I doubt its stressing the cpu very much
Yes, indeed (between 3% - 5% CPU usage) but I notice that customclientraw creation is every 4 seconds except a few times that is created at a 5 seconds interval and I don’t know it’s because clientraw is being created at the same time.
Anyway the performance is very fast.
Best regards
what speed pc and how much memory?
https://www.msi.com/Desktop/Wind-Box-DC111.html#hero-specification
Win10 Pro with VVP + 2 WD (WMR100N and VP2) + Cumulus MX running
so 2 versions of WD running as well as cumulus mx?
Yes, I said that.
Any incompatibility or low performance running those programs at the same time ?
They seem to run smoothly
P.D. Only WD with VP2 is creating clientraw and customclientraw files. Cumulus MX is creating realtime file every 4 seconds
That’s quite a heavy load for a relatively low power CPU. I think you can expect it to be hitting the CPU resource pretty hard, nothing wrong with that.
CPU’s get bored when they have nothing to do :wink:
