Rainwise IP-100
am I correct in thinking, that to connect to the IP-100, you simply check the box in WD to say it is being used, and ensure the correct IP address?
Keith
yes…and then restart WD…
and then check for info/errors under view, program event log and view, debug info
IP-100 arrived. have registered and data is being uploaded to Rainwise.net ( https://rainwise.net/weather/mm0ktc ). I have tried to connect to the IP-100 through WD, but nothing… I have checked there IP address are correct, have tried checking both boxes in the raionwise settings menu, but no data being displayed. I am sure I am doing something wrong, just not sure what. help would be appreciated.
Update
I notice that when I restart WD, the IP address is not saved, and goes back to - 192.168.2.3:80/, also tried adding http:// in front of ip address.
UPDATE 17.12.2016 - 19:54hrs
change IP address and used https://000.000.0.00 (zeros replace actual address) seems to work now… however, the IP address still shows 192.168.2.3:80/
Keith
Brian
data has stopped / or is very slow from the IP-100. the data file, IP-100.txt appears to be updating every minute, but the data display / count does not change, and / or is very slow. in approx 1hr a count of 3 is seen. any thoughts?
Keith
does restarting WD help?
Brian
restarting does not help.
when you say the file updates every minute, is the data in that file updating/changing?
Brian
yes, data is being updated.
Keith
just to recap, as its not very clear
so the data in that file is updating every minute or so (you have checked that)
but the WD is not ?
e.g there is periods of no data?
what does the graphs look like?
screen shot?
if you could email me the file ip100.txt
from the data files folder
when the data in that file has updated, but WD has not updated
Brian
screen shot and ip-100.txt file. data appears to be revived, but WD not displaying data.
keith
ip100.txt (2.67 KB)
use a new update to fix this :wink:
Brian
]that worked, and data on nWD is now updating. the update is slow, but I assume that is the rate at witch data is sent from the IP-100 / Rainwise Mk3.
Keith
is WD responsive while its not updating?
if you have ticked to log the raw data under ,setup, advanced/misc, what then shows under view, debug info
in relation to ip100 counter=
i.e how often is that changing?
are you able to port foward the IP100 so I can test here?
Brian
I will email you with port forward info, if I’ve got it correct…
WD is not responsive between data updates, WD updates every 10 - 15 seconds.
I have ticked the box to create ‘rawultimeterdata.txt’ and have attached a copy.
Also the battery volts no longer displays voltage, it shows zero all the time.
below is an extract from the debug info if it helps.
Loaded all time records
Loaded units
temp 2.8
hum 85
baro1007.79
,4.8,
wind4.8
dir315
wind2.6
rain0.0
rain mm 0.0
change in rain mm 0.0
temp 2.8
hum 85
baro1007.79
,3.2,
wind3.2
dir315
wind4.0
rain0.0
rain mm 0.0
temp 2.8
hum 85
baro1007.79
,1.6,
wind1.6
dir315
wind3.0
rain0.0
rain mm 0.0
temp 2.8
hum 85
baro1007.79
,3.2,
wind3.2
dir315
wind2.8
rain0.0
rain mm 0.0
temp 2.8
hum 85
baro1007.79
,6.4,
wind6.4
dir270
wind3.5
rain0.0
rain mm 0.0
temp 2.8
hum 85
baro1007.79
,4.8,
wind4.8
dir270
wind3.8
rain0.0
rain mm 0.0
temp 2.8
hum 85
baro1007.79
,3.2,
wind3.2
dir315
wind3.7
rain0.0
rain mm 0.0
temp 2.8
hum 85
baro1007.79
,6.4,
wind6.4
dir270
wind3.9
rain0.0
rain mm 0.0
temp 2.8
hum 85
baro1007.79
,4.8,
wind4.8
dir270
wind5.1
rain0.0
rain mm 0.0
temp 2.2
hum 85
baro1007.79
,4.8,
wind4.8
dir270
wind5.7
rain0.0
rain mm 0.0
temp 2.2
hum 85
baro1007.79
,3.2,
wind3.2
dir270
wind5.0
rain0.0
rain mm 0.0
temp 2.2
hum 85
baro1007.79
,3.2,
wind3.2
dir292
wind4.3
rain0.0
rain mm 0.0
temp 2.2
hum 85
baro1007.79
,4.8,
wind4.8
dir292
wind3.8
rain0.0
rain mm 0.0
temp 2.2
hum 85
baro1007.79
,9.7,
wind9.7
dir292
wind8.0
rain0.0
rain mm 0.0
temp 2.2
hum 85
baro1007.79
,8.0,
wind8.0
dir292
wind8.3
rain0.0
rain mm 0.0
temp 2.2
hum 85
baro1007.79
,4.8,
wind4.8
dir292
wind6.1
rain0.0
rain mm 0.0
temp 2.2
hum 85
baro1007.79
,9.7,
wind9.7
dir292
wind6.5
rain0.0
rain mm 0.0
temp 2.2
hum 85
baro1007.79
,8.0,
wind8.0
dir292
wind6.9
rain0.0
rain mm 0.0
temp 2.2
hum 85
baro1007.79
,4.8,
wind4.8
dir292
wind6.2
rain0.0
rain mm 0.0
temp 2.2
hum 85
baro1007.79
,9.7,
wind9.7
dir292
wind8.0
rain0.0
rain mm 0.0
temp 2.2
hum 85
baro1007.79
,8.0,
wind8.0
dir292
wind8.3
rain0.0
rain mm 0.0
temp 2.2
hum 85
baro1007.79
,6.4,
wind6.4
dir292
wind7.3
rain0.0
rain mm 0.0
temp 2.2
hum 85
baro1007.79
,4.8,
wind4.8
dir292
wind6.6
rain0.0
rain mm 0.0
temp 2.2
hum 85
baro1007.79
,4.8,
wind4.8
dir292
wind6.4
rain0.0
rain mm 0.0
temp 2.2
hum 85
baro1007.79
,3.2,
wind3.2
dir292
wind5.9
rain0.0
rain mm 0.0
temp 2.2
hum 85
baro1007.79
,3.2,
wind3.2
dir292
wind5.5
rain0.0
rain mm 0.0
temp 2.2
hum 85
baro1007.79
,4.8,
wind4.8
dir292
wind3.0
rain0.0
rain mm 0.0
temp 2.2
hum 85
baro1007.79
,4.8,
wind4.8
dir292
wind3.9
rain0.0
rain mm 0.0
temp 2.2
hum 85
baro1007.79
,4.8,
wind4.8
dir292
wind4.0
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
ip100.txt location=/Users/keithwhite/Documents/wdisplay/datafiles/ip100.txt
requesting data from http://192.168.1.8/weather.json
temp 2.2
hum 85
baro1007.79
,3.2,
wind3.2
dir292
wind4.7
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
temp 2.2
hum 85
baro1007.79
,4.8,
wind4.8
dir292
wind4.8
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
temp 2.2
hum 85
baro1007.79
,8.0,
wind8.0
dir292
wind6.4
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
temp 2.2
hum 85
baro1007.79
,3.2,
wind3.2
dir292
wind5.9
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
temp 2.2
hum 85
baro1007.79
,4.8,
wind4.8
dir292
wind5.7
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
temp 2.2
hum 85
baro1007.79
,6.4,
wind6.4
dir292
wind5.8
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
temp 2.8
hum 86
baro1008.13
,3.2,
wind3.2
dir292
wind5.6
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
temp 2.8
hum 86
baro1008.13
,3.2,
wind3.2
dir292
wind5.2
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
temp 2.8
hum 86
baro1008.13
,4.8,
wind4.8
dir247
wind4.8
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
temp 2.2
hum 85
baro1008.13
,4.8,
wind4.8
dir247
wind6.4
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
temp 2.2
hum 85
baro1008.13
,1.6,
wind1.6
dir247
wind5.1
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
temp 2.2
hum 85
baro1008.13
,3.2,
wind3.2
dir270
wind4.6
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
temp 2.2
hum 85
baro1008.13
,4.8,
wind4.8
dir315
wind4.9
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
temp 2.2
hum 85
baro1008.13
,4.8,
wind4.8
dir315
wind4.9
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
temp 2.2
hum 85
baro1008.13
,4.8,
wind4.8
dir315
wind4.3
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
temp 2.2
hum 85
baro1008.13
,4.8,
wind4.8
dir315
wind4.1
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
temp 2.2
hum 85
baro1008.13
,4.8,
wind4.8
dir315
wind4.4
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
temp 2.2
hum 85
baro1008.13
,4.8,
wind4.8
dir315
wind4.4
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
temp 2.2
hum 85
baro1008.13
,3.2,
wind3.2
dir315
wind4.2
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
temp 2.2
hum 85
baro1008.13
,1.6,
wind1.6
dir315
wind3.8
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
temp 2.2
hum 85
baro1008.13
,3.2,
wind3.2
dir315
wind2.4
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
temp 2.2
hum 85
baro1008.13
,1.6,
wind1.6
dir315
wind1.8
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
temp 2.2
hum 85
baro1008.13
,1.6,
wind1.6
dir315
wind1.7
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
temp 2.2
hum 85
baro1008.13
,0.0,
wind0.0
dir315
wind1.5
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
temp 2.2
hum 85
baro1008.13
,1.6,
wind1.6
dir315
wind1.5
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
temp 2.2
hum 85
baro1008.13
,1.6,
wind1.6
dir315
wind1.6
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
temp 2.2
hum 85
baro1008.13
,6.4,
wind6.4
dir292
wind5.9
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
temp 2.2
hum 85
baro1008.13
,6.4,
wind6.4
dir292
wind5.6
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
temp 2.2
hum 85
baro1008.13
,6.4,
wind6.4
dir292
wind6.3
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
temp 2.2
hum 85
baro1008.13
,6.4,
wind6.4
dir292
wind6.3
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
temp 2.2
hum 85
baro1008.13
,6.4,
wind6.4
dir292
wind6.3
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
temp 2.2
hum 85
baro1008.13
,6.4,
wind6.4
dir292
wind6.3
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
temp 2.2
hum 85
baro1008.13
,3.2,
wind3.2
dir270
wind4.0
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
temp 2.2
hum 85
baro1008.13
,1.6,
wind1.6
dir270
wind2.8
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
temp 2.2
hum 85
baro1008.13
,1.6,
wind1.6
dir270
wind2.6
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
temp 2.2
hum 85
baro1008.13
,1.6,
wind1.6
dir270
wind2.4
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
temp 2.2
hum 85
baro1008.13
,1.6,
wind1.6
dir270
wind2.4
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
temp 2.2
hum 85
baro1008.13
,1.6,
wind1.6
dir270
wind2.2
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
temp 2.2
hum 85
baro1008.13
,1.6,
wind1.6
dir270
wind2.2
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
temp 2.2
hum 85
baro1008.13
,6.4,
wind6.4
dir315
wind2.5
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
temp 2.2
hum 85
baro1008.13
,4.8,
wind4.8
dir315
wind2.9
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
temp 2.2
hum 85
baro1008.13
,6.4,
wind6.4
dir315
wind6.4
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
temp 2.2
hum 85
baro1008.13
,8.0,
wind8.0
dir292
wind6.4
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
temp 2.2
hum 85
baro1008.13
,4.8,
wind4.8
dir315
wind6.8
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
temp 2.2
hum 85
baro1008.13
,1.6,
wind1.6
dir315
wind5.7
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
temp 2.2
hum 85
baro1008.13
,4.8,
wind4.8
dir315
wind5.5
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
temp 2.2
hum 85
baro1008.13
,4.8,
wind4.8
dir315
wind5.6
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
temp 2.2
hum 85
baro1008.13
,6.4,
wind6.4
dir315
wind5.4
rain0.0
rain mm 0.0
ip100 counter=1
ip100 counter=2
ip100 counter=3
temp 2.2
hum 85
baro1008.13
,3.2,
wind3.2
dir315
wind4.2
rain0.0
rain mm 0.0
ip100 counter=1
i have your port forwarded IP working here
and WD is getting new data every 10 seconds or so OK
is that what is happening for you?
re battery
I was not pulling that data
I can do that though
