I did notice when I was configuring gauges.js that the images directory was incorrect. I changed :‘/images/’ to :‘/wxgraphs/’. It didn’t work so I posted here. I did notice that you had :‘./wxgraphs/’ (you had a dot before the forward slash). I changed that but it still doesn’t work. Thank maybe I’m missing something else.
Not really. I just copied and pasted it wrong into the message. Another thing that I do not understand. I only have the outdoor and indoor temperature configure. Shouldn’t I be getting a file not found when I put the mouse over other gauges? I was using graphs created by another weather program on a Mac earlier hence the jpg file names.
// Weather Display
_realtimeVer = 12; //minimum version of the realtime JSON file required
config.realTimeURL = config.longPoll ? config.realTimeURL_LongPoll : config.realTimeURL_WD;
config.tipImgs = [ // config.tipImgs for Weather Display users with wxgraph
[‘temp+hum_24hr.php’, ‘indoor_temp_24hr.php’], // Temperature: outdoor, indoor
// Temperature: dewpoint (Garage), apparent, windChill, heatIndex, humidex
[‘customgraph1.jpg’, ‘temperature1.jpg’, ‘windchill1.jpg’, ‘heatindex1.jpg’, ‘temperature1.jpg’],
‘precipitationc1.jpg’, // Rainfall
‘precipitation1.jpg’, // Rainfall rate
[‘rh1.jpg’, ‘rhin1.jpg’], // Humidity: outdoor, indoor
‘pressure1.jpg’, // Pressure
‘windspeed1.jpg’, // Wind speed
‘winddirection1.jpg’, // Wind direction
(config.showUvGauge ? ‘uv1.jpg’ : null), // UV graph if UV sensor is present | =null if no UV sensor
(config.showSolarGauge ? ‘solarrad1.jpg’ : null), // Solar rad graph if Solar sensor is present | Solar =null if no Solar sensor
(config.showRoseGauge ? ‘winddirection1.jpg’ : null),// Wind direction if Rose is enabled | =null if Rose is disabled
(config.showCloudGauge ? ‘cloudbase1.jpg’ : null) // Pressure for cloud height | =null if Cloud Height is disabled
They work on the Mac using Safari but not on the Mac using Chrome. The graphs appear to be working on Chrome for windows and Internet Explorer so the problem appears to be with Mac and Chrome.
