Author Topic: Consolewd on R-pi - requesting data  (Read 374 times)
Offline n7dq
  • Windsor, CO
  • Win NT 10.0
  • Chrome 53.0.2785.143
    • Windsor, CO - Weather -- N7DQ
« on: October 14, 2016, 01:16:28 AM »
Just got my Raspberry Pi setup and consolewd running.  I start the program as documented and I see the following and then just a constant requesting data.
Comport /dev/ttyUSB0 opened
setting baud rate to 19200 ->0
waking VP
requesting data
requesting data
I thought I would see more here on the screen.
Thoughts?
Mike
Mike - N7DQ
http://www.n7dq.com/weather
CWOP: AT059
WeatherUnderground: KCOWINDS8
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
Re: Consolewd on R-pi - requesting data
« Reply #1 on: October 14, 2016, 04:24:54 AM »
there is a flag in the config to set if you have a usb data logger
try setting that (then restart)
Offline n7dq
  • Windsor, CO
  • Win NT 6.2
« Reply #2 on: October 14, 2016, 04:55:32 PM »
Brian,
I changed that value with no luck but also tried changing "Davis com Method" from 1 to 2 along with your change it no works.
Also, got udev to give the account rw to the serial port since I don't like to sudo things under root unless I have to in the area of batch jobs.
Mike
Mike - N7DQ
CWOP: AT059
