hello,
I dn’t know why wxsi doesn’t close after automatic run.
What is wrong?
hello,
What is wrong?
Under schedule settings there is an option to have it close.
I suddenly have the same issue, it doesnt close, even though the box is ticked as per screen shot above. If I run it manually and click Activate with these settings, it runs and closes ok
Make sure you do NOT have the box called “Leave output on screen until next run” checked. Does the problem persist after you make sure of that?
Tom
It is unchecked. Doesn’t happen all the time. But cannot work out why. It stopped doing it and now a week later started again
I think it was:
“Close program after autorun” checked
but “archive”,“graphic”,“External boot” and wxf only were unchecked
Is it working OK now?
Tom
