New power adaptor with 4,75A power
4Gb Extra RAM now 8 Gb win 7 CPU 1.8Ghz
updated to Version wdisplay10.37S Build 59
It runs from yesterday 22.50 h till this morning 7.05h
then all my settings disappear
with daily backup reg file set it back all and now Version wdisplay10.37R Build 81 (last good acting version date 27072016)
Program error log file:
error with create files Failed to get data for ‘do option’
Above error or program log occured at :07 06 02 28/10/2017
error with do timer 1 via units Failed to create key Image download ani seq
error with timer42 Failed to create key Web cam capture
Above error or program log occured at :07 06 04 28/10/2017
Above error or program log occured at :07 06 05 28/10/2017
etc etc
I have not seen other reports of this problem you are getting so not sure why you are getting it
are you running WD as administrator?
what other programs run at the time this problem occurs?
(i.e they might be interfering with WD)
do you though happen to have WD set to create a animated web cam image (e.g from a http download)
that might be where the problem is
Till that last version 37Rb81 no complains about updates, after those it went wrong
are you running WD as administrator? yes
(i.e they might be interfering with WD) System Scheduler
WXsim
Wxsimlite
Wxsim autolearn
Avast AV
as a test you could try turning that off Turned it off in wdisplay10.37S Build 59
no difference
moviemakerlog.txt:
[b]***Can do convert.
#4232.4: [asf @ 03A91EC0] Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead. #4232.5: Output #0, asf, to ‘D:\Wdisplay\alldayvideo\videolastday.wmv’: #4232.5: Metadata: #4232.5: WM/EncodingSettings: Lavf57.41.100 #4232.5: Stream #0:0: Video: wmv1 (WMV1 / 0x31564D57), yuv420p, 320x240, q=2-31, 200 kb/s, 15 fps, 1k tbn, 15 tbc #4232.5: Metadata: #4232.5: encoder : Lavc57.48.101 wmv1 #4232.5: Side data: #4232.5: cpb: bitrate max/min/avg: 0/0/200000 buffer size: 0 vbv_delay: -1 #4232.5: Stream mapping: #4232.5: Stream #0:0 → #0:0 (rawvideo (native) → wmv1 (native)) (Video)
FrameInput [Canvas] read frame #1
FrameInput [Canvas] read frame #2 #4232.3: [wmv1 @ 03AC9040] Invalid pts (0) <= last (0) #4232.2: Video encoding failed #4232.0: Video encoding failed
FrameInput read close
[/b]
Let WD run now and let you know when settings disappear/fails
Found a moviemaker_avcodec-54.exe from 20-06-2013 8O and it creates a alldaymovie.wmv
Let it run without create a animated web cam image (e.g from a http download)
see what happens
if no errors will start that again (eusa_pray.gif)
Oh oke I think I renamed it because of the av codec-54 specially ; Will search the forum here for it.
But it’s still working ! glad to
maybe I can send that moviemaker.exe dated 20-06-2013 to you to investigate ?
only error today was:
error with animated http gif create Failed to create key Animated http file
Above error or program log occured at :05 06 02 09/11/2017
but it runs each hour and no problems so I don’t know what happens at that time
