Updated a 2 weeks ago to version 37S b15 for Windows
Now and then (but this morning) have errors and WD stops (can open program but no reaction at save and exit:
Restarting solves the problem but then back again (once in 2-3 days)
Errors:
ERROR: Failed to get data for ‘light intensity’ System.Win.Registry at time/date 8:5:6:659 01/08/2016
Above error or program log occured at :08 05 06 01/08/2016
error with doftpupload Failed to create key Webcamuploadaswell
error with do timer 1 via units Failed to create key Agenda
error with timer42 Failed to create key Web cam capture
error with do timer2 via units Failed to create key New webfiles location
Above error or program log occured at :10 04 31 01/08/2016
Above error or program log occured at :10 06 19 01/08/2016
V 37S b15
Restarted Windows cleanup/inspect/correct the drive 4 days ago
any error related to failed to create key
is a failure with reading or writing to the registry
in normal operation that should not be happening
you could running a registry cleaner maybe
As I searched in the internet for this to do - registry cleaner - it’s not recommended for win 7.
Windows has no errors so I leave that possibility
The previous version 37R b 81 had no issues like this, it started with this new vers of WD
I only noticed new moviemaker is not working so I went back to previous version (see error txt)
As I said I did a disk control (and a sfc/ scannow), no problems.
It’s new to me this errors.
yesterday
Current warmest day value (oC) 19.8 18:00:28 08/01/2016
Above error or program log occured at :18 00 28 01/08/2016
Resetting coldest night values 18:01:31 08/01/2016
Above error or program log occured at :18 01 31 01/08/2016
error with new charts Access violation at address 00748F9E in module ‘WeatherDisplay.exe’. Read of address FFFF6C70
Above error or program log occured at :18 20 12 01/08/2016
error with new charts 6am/6pm Access violation at address 00748F9E in module ‘WeatherDisplay.exe’. Read of address FFFF6C70
Above error or program log occured at :18 31 34 01/08/2016
error with animated http gif create Failed to create key Animated http file
Above error or program log occured at :22 04 04 01/08/2016
today/this morning
Above error or program log occured at :05 20 11 02/08/2016
Current coldest night value (oC) 16.7 06:00:11 08/02/2016
Above error or program log occured at :06 00 11 02/08/2016
Resetting warmest day values 06:01:31 08/02/2016
Above error or program log occured at :06 01 31 02/08/2016
Above error or program log occured at :06 31 34 02/08/2016
So ‘only’ new charts and warmest day/coldest night cause most errors
Whole day no problem till 'resetting day/night value’m starts at 18h and 6h
What does it do exactly?
Current warmest day value (oC) 16.2 18:00:27 08/02/2016
Above error or program log occured at :18 00 27 02/08/2016
Resetting coldest night values 18:01:31 08/02/2016
Above error or program log occured at :18 01 31 02/08/2016
Above error or program log occured at :18 20 11 02/08/2016
Above error or program log occured at :18 31 34 02/08/2016
Above error or program log occured at :19 05 06 02/08/2016
Less ‘failed to create keys’ for the moment (after did a chkdsk/r again, uninstall/install 37Sb15) that feels good , but:
Now I have a ‘System.SysUtils at time/date’ error for minutes and then it quit (but it happens before and there was a thread about it in juli/2015) http://discourse.weather-watch.com/t/60295 but that was not the clue for me.
I do not know what happens at that time what can cause this error, there’s a lot of create/uploads at that time :?
ERROR: Access violation at address 00748F9E in module ‘WeatherDisplay.exe’. Read of address FFFF6C70 System.SysUtils at time/date 15:1:24:816 03/08/2016
Above error or program log occured at :15 01 24 03/08/2016
ERROR: Access violation at address 00748F9E in module ‘WeatherDisplay.exe’. Read of address FFFF6C70 System.SysUtils at time/date 15:1:32:683 03/08/2016
Above error or program log occured at :15 01 32 03/08/2016
ERROR: Access violation at address 00748F9E in module ‘WeatherDisplay.exe’. Read of address FFFF6C70 System.SysUtils at time/date 15:5:30:579 03/08/2016
Above error or program log occured at :15 05 30 03/08/2016
ERROR: Access violation at address 005223E9 in module ‘WeatherDisplay.exe’. Read of address 00000010 System.SysUtils at time/date 15:5:53:148 03/08/2016
Above error or program log occured at :15 05 53 03/08/2016
ERROR: Access violation at address 005223E9 in module ‘WeatherDisplay.exe’. Read of address 00000010 System.SysUtils at time/date 15:6:0:168 03/08/2016
Above error or program log occured at :15 06 00 03/08/2016
ERROR: Access violation at address 005223E9 in module ‘WeatherDisplay.exe’. Read of address 00000010 System.SysUtils at time/date 15:6:0:486 03/08/2016
ERROR: Access violation at address 005223E9 in module ‘WeatherDisplay.exe’. Read of address 00000010 System.SysUtils at time/date 15:6:13:208 03/08/2016
Above error or program log occured at :15 06 13 03/08/2016
ERROR: Access violation at address 005223E9 in module ‘WeatherDisplay.exe’. Read of address 00000010 System.SysUtils at time/date 15:6:13:531 03/08/2016
ERROR: Access violation at address 005223E9 in module ‘WeatherDisplay.exe’. Read of address 00000010 System.SysUtils at time/date 15:6:15:374 03/08/2016
Above error or program log occured at :15 06 15 03/08/2016
ERROR: Access violation at address 005223E9 in module ‘WeatherDisplay.exe’. Read of address 00000010 System.SysUtils at time/date 15:6:18:200 03/08/2016
Above error or program log occured at :15 06 18 03/08/2016
ERROR: Access violation at address 005223E9 in module ‘WeatherDisplay.exe’. Read of address 00000010 System.SysUtils at time/date 15:6:19:172 03/08/2016
Above error or program log occured at :15 06 19 03/08/2016
ERROR: Access violation at address 005223E9 in module ‘WeatherDisplay.exe’. Read of address 00000010 System.SysUtils at time/date 15:6:32:257 03/08/2016
Above error or program log occured at :15 06 32 03/08/2016
ERROR: Access violation at address 005223E9 in module ‘WeatherDisplay.exe’. Read of address 00000010 System.SysUtils at time/date 15:6:46:640 03/08/2016
Above error or program log occured at :15 06 46 03/08/2016
ERROR: Access violation at address 005223E9 in module ‘WeatherDisplay.exe’. Read of address 00000010 System.SysUtils at time/date 15:6:48:170 03/08/2016
Above error or program log occured at :15 06 48 03/08/2016
ERROR: Access violation at address 005223E9 in module ‘WeatherDisplay.exe’. Read of address 00000010 System.SysUtils at time/date 15:7:40:613 03/08/2016
Above error or program log occured at :15 07 40 03/08/2016
WD is still running with approx 230Mb memory stable [-o<
I remember correctly, I think you had access violation errors with build 81 too?
yes you did.
What I did in the meanwhile:
Went back to Win7 firewall
Another AV program (Avast)
several times harddisk investigations (disk is ok)
memory check (2GB and ok)
back to 1037R b 81
Then all runs like a charm since that. What left is '151: HTTP protocol error. 301 Moved Permanently.
Above error or program log occured at :04:05 30/10/16’in program error log: that’s WU moved to https so no problem.
Unfortunately I cannot update to latest version of WD; it runs good till about 02.00am, after that all settings in WD disappear !
Back to the latest reg settings in backup solved that but then at aprox 02.00am same issue.
So I’m happy with 1037R b 81 now as long it has no other problems, but (offtopic:) as Awekas change to another server I cannot update with WD, and that should be a pain.
Maybe I’m wrong but try diconnecting a day or so from the internet, turn off all your antivirus & Firewall and see if WD works properly. If so, turn the Firewall on and see. I that works ok, then try the AV program.
Where you are at, I would be to the point of trying anything.
First error was at 15.06h : ERROR: 3: System.SysUtils (???)
Then at 17.06h :
error with do timer 1 via units Failed to create key Image download ani seq
Above error or program log occured at :17 06 01 01/11/2016
Above error or program log occured at :17 06 02 01/11/2016
Above error or program log occured at :17 06 03 01/11/2016
etc etc
At 17.58 it all blows up:
Above error or program log occured at :18 56 47 01/11/2016
ERROR: ''1 0'' is not a valid integer value at time/date 18:58 01-11-16
Above error or program log occured at :18:58 01-11-16
WD looks like this: no more settings (see att 2) looks to me like a ‘out of memory’ issue
Logfiles mashed up; this is VPlogfile (see att 3)
#-o
Back to 37Rb81 works good again (corrected WD/VP logfiles first before start)
New power adaptor with 4,75A power
4Gb Extra RAM now 8 Gb win 7 CPU 1.8Ghz
updated to Version wdisplay10.37S Build 59
It runs from yesterday 22.50 h till this morning 7.05h
then all my settings disappear
with daily backup reg file set it back all and now Version wdisplay10.37R Build 81 (last good acting version date 27072016)
Program error log file:
error with create files Failed to get data for ‘do option’
Above error or program log occured at :07 06 02 28/10/2017
Above error or program log occured at :07 06 04 28/10/2017
Above error or program log occured at :07 06 05 28/10/2017
etc etc
I have not seen other reports of this problem you are getting so not sure why you are getting it
are you running WD as administrator?
what other programs run at the time this problem occurs?
(i.e they might be interfering with WD)
do you though happen to have WD set to create a animated web cam image (e.g from a http download)
that might be where the problem is
