1.7 optional modules to use various data from weather-display,cumulus,meteobridge,ws1001,weatherflow
2.now possible via simple easyweathersetup to shuffle around the positions to show various data of your choice
at present there are 7 modules and as time goes by there will be additional ones .
3.the new modules at present are only in english sometime in the near future i will update these use multiple languages
4.new icons , new css files , new index.php , new easyweathersetup.php, new settings1.php and so on
so please do full update and not use existing previous version or mix with previous versions.
5.permonce remains the same and the new module idea has no impact on performance see screenshot below.
performance
feel free to drop me an email with any ideas or suggestions to use in these modules.
Is there any chance you could add sunshine hours to clientraw.txt so that it can be included in the latest version of the design template? Brian U has added a cell at the top to record sunshine hours, but at the moment it only works with cumulus as its not a value recorded in clientraw?
Clientrawextra please send me a copy of working or current file, its needs to be added into the live data.php and adding on
To easyweaathersetup to set the path so template knows where to look for it as I’m guessing every site will have a different path.
Ramadan begins this weekend and I’m off to football Sunday and then I’m off galavanting so after this weekend if it’s not done it will be sometime unfortunately before I can address these and issue an update.i will try today(Thursday) if I receive a file.
Well I’ve done everything, I’ve setup the template to use clientrawextra.txt however I need to find some sort of documentation as there are so many data values it’s a bit of nightmare to decipher, would I be wrong in saying there are over 800+ of different values to use in that file .
So I have not uploaded it yet , fixed other things as well and created a sunshine for weather display users and selectable options in the easywethersetup. I will look at it again tonight see if can work out the values.
Looks like clientrawextra outputs sunshine hours as a decimal. Is there any easy way to convert it to hours and minutes? WD shows my sun hours for today as 12hr 26 min, but in clientrawextra it is coming out as 12.4?
