Brian,
What is the upcoming optional module feature?
I am intrigued…also wondered whether you have found a simple MySQL solution?
Thanks again for helping me at the weekend.
Paul
Brian,
Paul
Thanks alot Brian, works now.
Nice template
nothing to exciting not sure it will be of interest to many but I know there is a select few who are Amateur Radio enthusiasts, but my past of chasing VHF weak signals has never left me and one of my relatives is on a northern lights trip at the moment so it kind of nudge me to finish this off which i started some time ago still work in progress need to add the A-INDEX from DK0WCY or VE7CC
CQ Aurora ! ur 59A i miss that distorted sound…
Hello
Version 3.4WF REQUIRES FULL Update(27 APRIL 2017)
available via https://weather34.com/homeweatherstation/
Version 3.4WF important to do full update many files updated .you may retain your settings1.php
Added K-Index aurora data pop up module
Fixed all timestamps issues noted with weather-display clientraw.txt file (Tnx P Wilman)
Fixed Wind Run not showing miles (Tnx P Wilman)
New updated timestamp method shows green dot icon for online with last time updated, shows orange dot icon when offline
New updated timestamp method for forecast data in current condition,forecast,outlook,hour modules & pop ups
All CSS files changed and includes fix in the light theme for incorrect temperature circle size when value is at 20-23c
index.php & indexearthquake updated to reflect 3 day forecast timestamp
easyweathersetup.php no longer uses to show updated or date & time oprion it is disabled .
Additional preparation for upcoming WEATHERFLOW hardware. version id moved to Version 3.4WF
Improved meteobridge-direct barometer trend output
outlook.php cleaned up code now works in your chosen preferred language set up in easyweathersetup.php
True timestamps for data last updated
All css files updated includes performance,changes to reflect timestamp,solar data and new additional code for upcoming optional module feature
solar1.php / solar2.php now reflect it is a UVINDEX forecast not a realtime measurement.
i hope this resolves all known issues emailed over the last two days sorry if I have not replied yet individually i will hopefully today. look forward to now finally get to grips with the new WEATHERFLOW hardware which arrived this morning. also some interesting stuff on the horizon , don’t know if it is just a coincidence but have received 4 requests from weather station hardware retailers to distribute the template FREE via
there online services/stores , 3 of them offer dedicated setup of template and web hosting packages . I need to just ensure that under NO circumstances does anyone actually pay for the template
and clearly states the template is freely available via https://weather34.com/homeweatherstation/ .There are many things going on and its all positive so i really think I have nailed in terms of user experience and making it attractive to enthusiasts and the casual enthusiast .
I openly thank you all without the feedback I would never see some of the issues that are raised and 90% of the time they are resolved , however I make no secret some mornings I just don’t look at my email till I have had a litre of filtered coffee then Im more positive .
have fun …Brian
Brian,
Just wanted to say a huge thanks for making the minor updates. It is always appreciated how quickly you made the changes. Glad your services and skills are being appreciated by weather flow and also the other manufacturers.
I am all updated to the latest version now.
Paul
hello Paul
no problem just spent the evening configuring the template for the WEATHERFLOW API probably one of the easiest pieces of hardware I have used and glad to say template is now ready for WEATHERFLOW hardware when it is readily available.
as they say all good things come to those that wait and bide there time quietly
have a nice weekend…
Hello thats some menu hope it works ok…
New Feature/Languages Updated/File Updates (30 APRIL 2017)
Weather Flow hardware full API support added(30 APRIL 2017)
Hello
It will show when risk of 60% or greater if you are using latest version , also I’m sorry I have not finished xuapi there are over 100 different weather icon combinations I’ve done about 123 just need double check I have not missed any . If you are still interested I can send along a copy of optional script and icon folder . You need to get an API key .
Brian
I slapped together an apixu script that seems to be working. I would still like to see yours though
Ok no problem will send along in the week sometime…
Brian
Do you know why the new Barometer Max and Min are in two different units?
hi fixed for some reason there was min barometer switch anyway all done just update the livedata.php
Languages Updated/Fixes (1 May 2017)
brian
Languages Updated/Important FIX (1 May 2017)
i wish we all spoke the same language be it english,french,russian,spanish or Mongolian language it would be easier
hello file updated just now
Language Updated/Fixes Alignment Languages (1 May 2017)
good night iyi aksamlar …
Brian,
Thanks for the great design, love all the quality design elements.
I am in the US and using a Davis VP2. So not using metric or 24h.
The last 2 iterations of PWS are presenting odd behavior on any graphs compiled from the clientraw.txt file generated by the weather display software.
Temp is roughly 2 or 3x the temp on clientraw.txt
Rainfall is roughly 1/2 rain on clientraw.txt
The Barometer is wacky
Please take a look at my site and just check the “Today” graph for Temp & Barometer to see what I am describing. Rain is less easy to discern unless it’s currently raining.
All displays are correct on front page, its just the graphs. Graphs generated on my other site generated by WeatherDisplay are correct. This site is accessible in the menu - “Weather site #1”. I did not notice this behavior on earlier iterations, but it does occur on V34WF & V34GM.
Not sure if this is discrete to my installation, which were full installations, but I seem to be the only user reporting this behavior.
http://www.loweprofile.com/pws/
Let me know if you want access to settings page.
Good morning
Nothing to do with your clientraw can you just pm your login password for easyweathersetup
Brian
should be ok now sent you a pm …take care …brian
Brian cleared that up for me. I screwed up the country selection. I didn’t understand the last question. I guess for me it was a trick question!!
Anyway…Make sure in Setup for your country to only answer “True” to one of the four questions (which is noted on the page also) otherwise you will get some wacky graphs.
