Brian I certainly will keep an eye on things, as I said I like the layout etc, if I do find tiime later I will see what I can come up with.
Ahhh, forgot the cron for the first #-o thanks
Hi all.
Anybody have no earthquake show in newest 4.36 template right now? see photo.
Can not manualy access the internet site http://www.seismicportal.eu maybe site its down.
Hi.
Yesterday i updated to complet package latest metric darkversionclientraw version 4.37D.
I now noticed that when my wind settings is set to use m/s, the wind shows on template compare to davis consol is aprox twice/dubble up. Example: on consol show 2 m/s, the template shows aprox 4 m/s.
Is there a script error somewhere to adjust?
Greate template
the data in clientraw.txt is always in the same units
not matter what is selected in WD
for conistancy
(i.e knots for windspeed)
Thanks for helping weatherist34
The clientraw.txt from weather display has wind in knots.
Im attaching the files her if you can edit and post, also for other to use when m/s is wanted
livedata.php.txt (13.3 KB)
10dayweather.js.txt (1.7 KB)
Thanks alot Brian u.
Files uploaded.
But seems not to work, blowing at shows zero and the 10dayweather.js still shows kmh.
See here:
See my live stream wind her:
Error log on host:
[27-Jul-2016 09:42:04 UTC] PHP Warning: file_get_contents(https://www.ulsteinvikweather.com/uw/clientraw.txt): failed to open stream: HTTP request failed! in /home/ulsterok/public_html/pws/livedata.php on line 2
[27-Jul-2016 09:42:04 UTC] PHP Notice: Undefined offset: 1 in /home/ulsterok/public_html/pws/livedata.php on line 4
[27-Jul-2016 09:42:04 UTC] PHP Notice: Undefined offset: 2 in /home/ulsterok/public_html/pws/livedata.php on line 5
[27-Jul-2016 09:42:16 UTC] PHP Warning: file_get_contents(https://www.ulsteinvikweather.com/uw/clientraw.txt): failed to open stream: HTTP request failed! in /home/ulsterok/public_html/pws/livedata.php on line 2
[27-Jul-2016 09:42:16 UTC] PHP Notice: Undefined offset: 1 in /home/ulsterok/public_html/pws/livedata.php on line 4
[27-Jul-2016 09:42:16 UTC] PHP Notice: Undefined offset: 2 in /home/ulsterok/public_html/pws/livedata.php on line 5
@All,
The files I’ve changed where kmh state instead of km/h can be downloaded via this link.
For the map “graphs”
10dayweather.js
3dayweather.js
weather.js
hour.php
And for the map “js”
combi.js
Download link: http://gofile.me/6nGNP/S8pY0PXVG
Piet
Can someone tell me where the update interval can be change This would be the update interval for the windspeed temp etc
Windgust
Thank you exactly what I wanted, I can adjust each value the way I want. Windspeed can be set to update quicker and temperature can update at a different interval. Now to fix why the Sunrise /sunset and moon times do not match Wdisplay and my graphs appear not to work.
http://www.windgust.com/newpage/nonmetric/index.php
Wind direction works a little funny but I can live with that.
Windgust
@windgust: What value do you have in settings php for:
$moonadj = ‘2’; //adjust this number to correct the moonset time output to your location should be either 1 or 2 will have to monitor this when clocks change back or forward. nz 1 uk 1 usa 1 istanbul 2//
? Try swapping 1 for 2 or 2 for 1.
Thanks, I will need to look into that one.
Also do I use the API key listed in the settings file or do I have to sign into my account and get my own.
I also see my UV is not working and my graphs are not working.
Back to re-checking everything, I think this is a great template I hope I can get it working.
Windgust
Dam I missed the solar2 change, I thought I had changed it. Guess not
What is the API key used for. I have my own station,
Do I need one ? Still working on the time for sunrise moonrise being off from Wdisplay
I now see the earthquake is blank.
is the API used for the graphing, Do you know what version of the API I need and do I have to add the API if needed on my server.
Windgust
Florian enabled php 5.5 on the WD server and I also setup external cron job activation via cron-job.org
and now my graph data, forecast data and earthquake data is working
http://www.weather-display.com/downloadfiles/idesign/demo/
I have also added the m/s version (I named it euro version). see links to download in first post in thread
I do notice a minor formatting problem when viewing the web
Page on my mobile phone (Android).in the wind area
Also this works fine on iphone 6 plus, ipad on the side/top ways around.
Hey,
Where can I change the section in the yellow circle from the Attachment.
From “Thu Jul 28th” to “Thu 28th Jul”
Piet
Trying to use cron-job.org I get a bad gateway.
I wonder if there a program I can run on the WD server to run a cron job and then upload it to my domain server.
The update would for cron for only be every 30 minutes or so.
I know WD has a croncloud I wonder if the Cron scripts could be modified to be like WD uses for the croncloud
Windgust
K1DED Amateur operator
Thanks Brain,
I have change it.
Was forgotten another question
The time display below will display 0:00:00 to 9:00:00 instead of 00:00:00 - 09:00:00
Where can I change that?
Piet
SO I checked my domain hosting company Yes its yahoo been with them over 15 years.
In my scripts log file I see this
Of course I have changed my API reg
[28-Jul-2016 11:35:26] PHP Warning: file_get_contents() [function.file-get-contents]: http:// wrapper is disabled in the server configuration by allow_url_fopen=0 in /newpage/nonmetric/cronfiles/stationcron.php on line 11
[28-Jul-2016 11:35:26] PHP Warning: file_get_contents(http://api.wunderground.com/api/3a72xxxxxxxxxx/conditions_v11/q/pws:KNHHOOKS3.json) [function.file-get-contents]: failed to open stream: no suitable wrapper could be found in /newpage/nonmetric/cronfiles/stationcron.php on line 11
[28-Jul-2016 11:35:26] PHP Warning: file_get_contents() [function.file-get-contents]: http:// wrapper is disabled in the server configuration by allow_url_fopen=0 in /newpage/nonmetric/cronfiles/stationcron.php on line 23
[28-Jul-2016 11:35:26] PHP Warning: file_get_contents(http://www.seismicportal.eu/fdsnws/event/1/query?limit=1&lat=43.0987&lon=-71.4569&maxradius=10&format=json&nodata=204&minmag=2) [function.file-get-contents]: failed to open stream: no suitable wrapper could be found in /newpage/nonmetric/cronfiles/stationcron.php on line 23
[28-Jul-2016 11:35:26] PHP Warning: file_get_contents() [function.file-get-contents]: http:// wrapper is disabled in the server configuration by allow_url_fopen=0 in /newpage/nonmetric/cronfiles/stationcron.php on line 34
[28-Jul-2016 11:35:26] PHP Warning: file_get_contents(http://www.seismicportal.eu/fdsnws/event/1/query?limit=1&lat=43.0987&lon=-71.4569&maxradius=100000&format=json&nodata=204&minmag=5) [function.file-get-contents]: failed to open stream: no suitable wrapper could be found in /newpage/nonmetric/cronfiles/stationcron.php on line 34
Anyone have some ideas, I believe this has to be my problem
PHP version 5.3.6
Windgust
