I have installed the scripts 3 times and uninstalled the same and am putting them in again. I keep getting an issue with
Error: You must manually upload an empty text file named /home/fipa/public_html/yass/weather28/fc/ and give it write permissions (CHMOD 666).
I can see that part in the php file but I dont understand why it doesn’t put the file name etc at the end of the string etc. Before I rip it out again and restart, can someone point me in the correct direction.
$fileLoc = “fc/”; // Location of these forecast files. “” if in the site root folder, otherwise something like “forecast/”
// You must also make a change in forecast-compare-inlude.php on line 25 if doing that.
but that change has not been made in forecast-compare-inlude.php. Try that and hopefully it will work.
I think your best bet would be to put all the files in your root folder and run the script from there. Don’t forget to undo those two references to the /fc/ folder.
Thanks Jim. Yes that seems to work. I like trying to keep stuff in their own folders in case something doesnt play nice but hey it now works so all good.
Checked it again this morning without changing anything and get the usual Error: You must manually upload an empty text file named /home/fipa/public_html/yass/weather28/ and give it write permissions (CHMOD 666).
SO what file would it be looking for some 14 hours after it ran yesterday?
