Steelseries
I recently installed steelseries gauges.
It works great and i have managed to change the language to norwegian also :slight_smile:
But i see alot have a sort of a small weather report on top of the page, how do i get that?
And how do i get a the bars to show when i hoover the mouse over the dials?
http://nesset-1.priv.no/gauges-ss-basic.htm
Sorry, I’m away on holiday at the moment. What you want is straight forward, hopefully somebody can chip in and point you in the right direction
the weather report for say my site comes from my Davis VP
i.e the custom tag
“forecast”:“%vpforecasttext%”
but if you do not have a davis VP, then you could change that to say the zambretti custom tag in the customclientrawlocal.txt
I have a Oregon WMR 300. will try to change it to zambretti and see if that works. or is there a special code for oregon stations?
But how do you get the charts to show when you hower the mouse over the gauges? its just blank page there for me.
there is other threads about setting up the graph scripts I think you will find on the forum
I think this is the one http://discourse.weather-watch.com/t/28585
That was a lot of information to read up on. guess this is not something i can get done by some easy clicking :slight_smile:
I can not figure out how to change the language on the gauges.
Does anyone know which folder it is located?
languge.min.js
(use notepad ++ to edit)
its in the scripts folder
there is also language.js in the src folder (but I think that is just for testing/development/debugging?)
I thought so, but this will be a long investigation, that there is really a lot.
See Mark’s reply in this thread too.
So I was able to install his tongue.
I renamed the names in the table that shows rollover, but as you can see in the picture inside should be a chart like the one pictured second.
We managed to have someone install a chart into a table?
