In case of power out, my PC reboots auto when power comes back.
WD then restarts auto also. I use “StartWatch” to have WDMysSQL
restart also, no problem.
Where the problem is, is the fact that Control Panel → Web Files/Web Page Rea Time… → Real Time clientraw… → Start now
does NOT trigger.
So the web site loads OK but is NEVER live updated.
Question: Is there something to set to have live weather run on startup???
do you have the main internet switch on in the connections setup in the FTP/internet setup?
Answer is NO as long as panel says:
“General FTP to ftp non WD files or…” As long as I do not need this feature I did not turn it on.
My testtags.php is uploading OK, NOAA files also and when real time is running, everything is OK.
So what should I do?
Activate the General FTP button?
enforce ‘clientrawrealtimeftp.exe’ to start with “StartWatch” after 10 seconds?
I do not know why you have this problem
I do not have any other reports of this problem
it will be something about your setup
if you could post some screen shots
