Tom,
I’m sorry I didn’t get this to you a few hours earlier but it is what it is.
Tom,
I am having a problem with the display of my Wxsim data since this latest round of revisions. First; my website display is smlweather.com/3in1WX.php. The problems are: precipitation amounts are not displayed, the Hour-by-Hour tab does not display, the Detailed 48 hrs tab does not display, and the Grass & Soil tab does not display. There may be more but that’s a good start. Now, I use WeatherLink for my local data feed. I have noticed over the years that if the “Time: latest or” does not match the “Effective time” in WXSimate, I get a similar set of errors.
I run my WXSim forecast every 4 hours and it is fouling up every time. If, after completion, I check the WeatherLink time, it is usually correct, and if I run Wxsimate, WxSimLite, and WxSim manually, the above errors are not present, ie. the display is correct.
Hopefully, you can find an easy bug to swat.
Thank You.
George
