I have been using HB1Wirereader with no problems until the other day, the version of WD is 10.37 S9, I have made no hardware changes but get the error message in the attached jpg, the message closes really quickly hence two snaps.
Any idea what the violation is so I can fix it.
Many thanks
Ian
there has been no change to that program for some time (you can tell by the modified time/date stamp)
I would need to add a crash report debug to it
Not sure what’s happened Brian, one day working happily, next an error, tried rebooting as you do, but still a problem, Dallas reader working fine and temp recording well.
Ian
Thanks for the speedy response, I’ve installed the degbug file, how do I get the information off WD?
Saw this thread and noticed that HB1wirereader was not running, manually restarted and got this error…
ERROR: Access violation at address 007B71E3 in module ‘HB1wirereader.exe’. Read of address 00000014 at time/date 10:24:06 AM 5/2/2016
Dallas reader with lightning detector and temp sensor still reporting OK.
Have been running ver 10.37S bld 9, since May 1. I have installed the new HB1wirereader.zip ver 3.5, manually restating reader gets the same error…
ERROR: Access violation at address 008BE28B in module ‘HB1wirereader.exe’. Read of address 00000014 at time/date 10:34:28 AM 5/2/2016
No useful information in Program Error Log…
Current coldest night value (oC) 11.4 06:00:06 05/01/16
Resetting warmest day values 06:00:31 May/01/2016
Resetting warmest day values 06:01:31 May/01/2016
error with mainform web cam image 2 Cannot open file “C:\wdisplay\allvideo\jpgwebcam.jpg”. The process cannot access the file because it is being used by another process
error with mainform web cam image 3 Cannot open file “C:\wdisplay\allvideo\jpgwebcam.jpg”. The process cannot access the file because it is being used by another process
Current warmest day value (oC) 11.0 18:00:07 05/01/16
Resetting coldest night values 18:00:31 May/01/2016
Resetting coldest night values 18:01:31 May/01/2016
Current coldest night value (oC) 12.0 06:00:07 05/02/16
Resetting warmest day values 06:00:31 May/02/2016
Resetting warmest day values 06:01:31 May/02/2016
Nothing useful in Program Debug Info…
10:09:01 uploading C:\wdisplay\alldayvideo\videolastday.flv
Doing checking of time zone calculation
Daylight saving in use
doftpdownmetarstation
10:13:22 uploading C:\wdisplay\alldayvideo\tensecondvideo.flv
dohamweather
LOO
10:23:04 uploading C:\wdisplay\alldayvideo\tensecondvideo.flv
LOO
dohamweather
10:33:05 uploading C:\wdisplay\alldayvideo\tensecondvideo.flv
Just tried restarting computer and WD with ver 3.5 HB1wirereader, same access error.
No information in error and debug logs.
Gus
Gus,
Thanks for posting up, we have a common issue , usually when things go wrong its’ because I’ve done something wrong lol
do you guys use the relay control?
Yes, I have an 8pt relay board
Gus
I think that will be the problem
drop box, which I use for the remote control, have changed their api
try turning that off in the registry
in wdisplayftp.ini
[12 volt switch to do]
do remote control
so that to no
Backed-up wdisplayftp.ini, exited WD, edited and reloaded.
do remote control=yes
Setting to “no” stopped the access error, HB1wirereader now running.
Relays look to be working without the remote control enabled.
Gus
Will now try new zip file.
yes, the relay will still work…just the remote control will not…
if you could try the new version with that registry setting set back to yes…
New zipfile - HB1wirereader ver 3.6
Ok with do remote=“no”
Edit and set to yes, get error…
ERROR: Access violation at address 007B831F in module ‘HB1wirereader.exe’. Read of address 00000014 at time/date 5:52:18 PM 5/2/2016
Gus
I have changed 12 volt switch to ‘no’, I wish I’d hung on a few minutes and followed how Gus did it, but I didn’t i.e not taking a back up and closing the program first, the upshot is that even with the switch set to no and the latest HB zip installed, I still get the error.
The file I edited is in wdisplay/databackup.
Ian
you need to actually edit the windows registry, wdsiplayftp.ini, in the registry, using regedit.exe
for that setting noted above
All sorted with the same results as Gus, thanks for your help as always.
Ian
found out more…Drop box dropped the API all together that I was using for the remote control
I could instead switch to using the cloud storage system that I have used for the WDliveapp
Ok, sounds good to me.
Gus
