Hello at all:
Yesterday at 12:59 weatherdisplay doesn
do the files exist in the directory its trying to upload from?
Yes, WD create the files, they are in webfiles folder, I am using virtual weather station to upload the files of webfiles. I use wd realtime ftp to upload clientraw.txt, the other files I upload by wetherdisplay FTP upload, It open some wd ftp upload repeats. In the evening I see that my web was not working then I thought that that I was a server problem, I Know that at 12:59 don
have you tried a pc reboot?
also try deleting all the files with a .tmp extension in the webfiles folder
in case they are locked or similar
also try reset/reselecting the webfiles and clientraw files folder in the webfiles/web page setup in WD
also you could try unticking to rename the files on the server , in the connections setup, as a test
My pc reboots twice a day, wd creates a clientraw.txttemp file and update this files every 10 seconds. There is more files with " .txttemp"
try also ticking
use passive mode
then restart the real time ftp program
Okkkkk, I put passive mode and realtime ftp works fine, and wd ftp upload quickly, before there is five wd ftp open but stopped.
I am sorry, do you think that 1and1 server change anything and to it I must put passive mode??
Thanks Mr. Brian.
I think they must have, yes
