the solution to that particular problem might be to reset/reselect the webfiles location in WD
also re the statement that newer versions will not run on the windows version used, it should do as long as all the available updates and patches are installed for that windows version
(e.g try googling for finding out how to do that)
You see the same for Cumulus issues too, if they are a bit tricky eventually somebody does usually say āyouād be best asking this on the Cumulus support forumā #-o
I guess its the same for all sorts of stuff - ask your mates first, then if all else fails refer to the specialists.
As one who had his knickers scared off him by Niko (not really) by getting a reply to a question I asked on Wxforum here, I was thinking Big Brother, if not Google, had decided to shift me to another forum.
Then he pointed out that I had joined here a long time ago, and didnāt notice that there was a shift.
I will never be able to use all the goodies that WD provides, and being on several hobbies at different intensities, even forget what boards I belong to.
Then when a computer bites the dust and I do a ground up rebuild, may forget that Iām a member of some groups, and never re establish a link and remember the passwords.
It makes sense to go to the forum where the author hangs out. That being said, there are those who say they are āresearchingā for othersā experience. I love it when advertisers imply that all the knowledge and only the ārightā knowledge is discoverable on the internet, especially when it leads them to buy whatever the advertiser is hawking that day. āI did my research and Iā¦ā
Thanks, Brian, for all you do. It has to be a nightmare dealing with so many settings, installations, site blockers, ad blockers and other things that keep things running. And then to convey it to the less computer inclined to try to get them to understand itā¦ Argh!
True, that, Brianā¦ thatās why Iād posted the āThis isnāt the official (software-name) forumā¦ā sticky posts for Weather-Display, Cumulus, Meteohub/Meteobridge, and WUHU in the respective forums with links to the specific URLs for the respective weather software. The WXForum.net forums are listed as āpeer supportā. We are lucky that developers like you and Boris do visit wxforum.net from time to timeā¦ thanks.
