Hi, NaN’s found in run 2016-03-31 06z
Fcast_hr, tmp2m, dp2m, wspd, wdir, tcdc, prmsl, hgtsfc, tmp850, rh700, hgt1000, hgt500, apcp
2016-03-31-06
+0,17.7,10.6,7.5,304.1,50.0,1011.5,276.6,6.9,53.9,97.9,5666.6,0.00,
+3,13.8,10.9,4.3,336.3,95.1,1011.9,276.6,7.0,64.9,101.4,5668.4,0.06,
+6,-266.9,NaN,0.0,94.6,100.0,0.0,0.4,-273.2,31079.5,220.8,-3.3,20577.83,
+9,13.6,12.7,4.9,344.0,99.0,1010.1,276.6,8.3,78.7,83.5,5650.2,1.06,
and GFS Data same line data screwy:
Fcast_hr, prmsl, apcp, tcdc, wspd, wdir, hgt1000, hgt500, tmp950, tmp925, tmp900, tmp850, tmp800, tmp750, tmp700, rh950, rh925, rh900, rh850, rh800, rh750, rh700, rh500, rh300
2016-03-31-06
+0,1011.5,0.00,50.0,7.5,304.1,97.9,5666.6,15.1,12.9,10.7,6.9,6.3,3.2,-0.0,66.4,73.5,81.8,93.7,71.2,66.0,53.9,75.0,99.6
+3,1011.9,0.06,95.1,4.3,336.3,101.4,5668.4,13.6,12.0,10.2,7.0,6.3,4.3,0.7,78.2,84.4,89.6,96.0,75.1,62.9,64.9,97.3,99.7
+6,0.0,20577.83,100.0,0.0,94.6,220.8,-3.3,-273.1,-275.8,-272.9,-273.2,-270.0,-44.4,-268.3,23842.7,-0.0,4.1,0.0,1.9,0.1,31079.5,1042.7,2.6
+9,1010.1,1.06,99.0,4.9,344.0,83.5,5650.2,13.2,12.1,10.4,8.3,6.3,3.4,0.8,89.7,92.3,96.3,92.7,86.6,87.3,78.7,98.6,99.8
regards,
Tony,
I didn’t have any NaNs in the WxSim-Lite 2016-03-31 06z run. However, forecast hour +6 looks very wrong:
+6,-263.8,-264.1,0.0,262.5,100.0,0.1,1.6,-273.1,30950.0,216.0,6.5,20551.07,
Steve
Tony,
Fortunately the 12z run looks clean. It doesn’t have any NaNs and I don’t see any strange looking data either.
Steve
For the past 3 model runs…I have been observing strange behavior in the actual text model data from NOAA…both NAM & GFS. Check out the high temperature(s) and relative humidity in the first period of my nearby metar site. The strange data maybe coming from NOAA and not associated with “Bohler Server”…since it would just pass along the bad data…but I really do not know. Just thought I would share this…
KVBT AVN MOS GUIDANCE 3/31/2016 1200 UTC
DT /MAR 31/APR 1 /APR 2 /APR 3
HR 18 21 00 03 06 09 12 15 18 21 00 03 06 09 12 15 18 21 00 06 12
N/X 131 39 61 34 64 41
TMP 64 66 62 54 47 43 41 50 56 58 54 46 41 38 35 46 58 64 60 46 42
NXR 5 89 31 70 25 76
HUM 48 40 43 51 54 56 58 46 33 29 31 44 53 57 62 48 32 28 34 63 71
XNH 131 39 61 34 64 41
HIX 64 66 62 54 47 43 41 50 56 58 54 46 41 38 35 46 58 64 60 46 42
DPT 44 41 39 36 31 28 27 30 27 26 24 25 25 24 23 27 28 30 31 34 33
CLD FW SC CL SC CL CL FW FW CL CL CL CL CL CL CL CL CL CL CL CL CL
WDR 27 28 30 29 31 34 29 32 31 30 32 33 32 34 32 28 28 30 31 08 16
NXW 131 36 59 29 64 41
WCH 63 66 62 53 44 41 38 46 53 55 52 44 41 38 35 42 56 63 60 46 42
WSP 11 12 06 04 06 04 04 11 10 12 07 05 03 03 02 07 11 11 05 01 02
P06 0 0 0 0 0 0 0 0 0 0 1
P12 1 0 0 0 1
Q06 0 0 0 0 0 0 0 0 0 0 0
Q12 0 0 0 0 0
T06 0/13 0/ 7 2/ 5 0/ 7 0/10 0/ 0 0/ 0 1/ 5 0/ 0 1/ 0
T12 0/17 3/10 0/10 2/ 5 0/ 0
POZ 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
POS 0 0 0 1 0 2 6 4 1 0 2 2 15 46 55 2 2 1 2 1 2
TYP R R R R R R R R R R R R R R S R R R R R R
SNW 0 0 0
CIG 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8
VIS 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7
OBV N N N N N N N N N N N N N N N N N N N N N
KVBT ETA MOS GUIDANCE 3/31/2016 1200 UTC
N/X 130 40 61 33 64 36
TMP 59 61 58 52 47 44 41 48 56 58 52 44 40 37 35 43 57 64 59 43 38
NXR 5 93 34 79 30 82
HUM 62 50 49 59 68 71 73 54 34 29 35 51 65 76 79 65 37 28 33 63 73
XNH 130 40 61 33 64 36
HIX 59 61 58 52 47 44 41 48 56 58 52 44 40 37 35 43 57 64 59 43 38
DPT 46 42 39 38 37 35 33 32 28 26 25 27 29 30 29 32 31 30 30 31 30
CLD BK BK OV CL SC CL CL CL SC BK CL CL CL CL CL CL CL CL CL CL CL
WDR 28 29 30 28 23 32 35 36 32 32 34 01 03 34 32 27 30 31 34 05 16
NXW 130 40 60 28 64 36
WCH 57 60 57 52 47 42 41 44 54 56 50 41 40 37 35 39 55 63 58 43 35
WSP 10 10 06 02 01 04 03 09 08 09 07 05 03 03 02 07 09 13 08 02 04
P06 1 1 1 3 7 2 2 0 0 0 2
P12 3 7 6 0 2
Q12 0 0 0 0 0
T06 0/12 0/11 1/ 5 0/ 3 0/ 5 0/ 4 0/ 0 0/ 0 0/ 1 0/ 0
T12 1/17 1/ 6 0/ 9 0/ 0 0/ 1
POZ 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
POS 0 0 0 2 2 0 1 2 2 2 3 4 14 25 19 7 2 2 1 2 4
TYP R R R R R R R R R R R R R R R R R R R R R
SNW 0 0 0
CIG 8 7 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8
Hi Steve,
Sorry late reply, yes all been good since that 06z issue.
tbrasel, not sure what’s going on there matey, hopefully Tom may shed some light on it for you.
regards,
Hi Tim,
Interesting catch there! That’s straight from NOAA, and nothing to do with WXSIM or Bohler or McMahon servers. Weird bug, with highs of 130 degrees F, with mid 60’s for the 3-hourly temps!
Thankfully, WXSIM does not read those max and min temps (though it does read the 3-hourly ones, for advection purposes).
If NOAA doesn’t catch that on their own soon, I’ll report it!
Thanks!
Tom
