Brian you probably don’t remember but in past beta’s you added a spike detection feature which fixed an issue i was having with gust spikes using the inspeed vortex. This worked great for many month’s but a few beta’s ago the problem has returned and i’m getting spikes everyday now. I’m wondering could you have a look and see has something changed that has disabled the feature?
I have not changed anything specificly to do with this code, but some other timing changes in other parts of the code might have an effect…but its hard to know where in the code
maybe you could use the version that was working OK ?
one thing I can do is to add a check against the max speed limit you can adjust in the limits setup
I’m not sure exactly which version was working ok but i would have a good idea going on the timings of when the spikes starting returning . I presume no problems to go back to earlier beta’s, zips?
