I have a test page working OK on jp 3.5 so give it a try, as I recall I had to make a small change to 3.5 to get the “old” format.
Bill, unfortunately, the pages you saw (when you clicked on my link) are way outdated … like really really outdated… :oops:
I have been working on some new and much more modern templates but I have not put them online yet … I keep pushing the date/year for the release of the new pages… :roll:
keep pushing the date/year for the release of the new pages... :roll:
Understand completely. I have a list of things I need to update but other things get in the way. :?
Bill, as you noticed on my site, the JpGraph do not seem to work well (or at all) with PHP 7… :oops:
Well, all of a sudden my graphs are working again with no changes on my part. Go figure. :scratch: Perhaps a setting on the server at my web host was changed?
What is wrong with me? What is it that I am doing wrong?
I can not see what is wrong
I have tried to follwo Tim Hankos guide.
I got the test.php and it replies that I have PHP 5.6.17 and GD support enabled
I got the jpgraph-3.5.0b1.tar
(I can not find the version 2.2 that Tim is pointing to)
Location for jpgraph is: /usr/local/www/apache24/data/jpgraph-3.5.0b1/
Broadstaris wxgraphs is in place: /usr/local/www/apache24/data/wxgraphs/
Did I get the graphsconf.php correct ?
//where are your clientraw*-files and JPGraph relative to where this file is^M
//note you should only need to change the jpgraph directory if you do not use standard names^M
//$hostloc = “${WEBROOT}/”; //must have trailing slash^M
$hostloc = “/usr/local/www/apache24/data/weather/weatherdata/”;^M
$jploc = “/usr/local/www/apache24/data/jpgraph-3.5.0b1/”; //must have trailing slash^M
^M
//Set this variable to either 12 or 24 depending on whether you run Weather Display in 12 or 24 hour mode^M
$hourmode = “24”;^M
When I run the hardpath.php I get: /usr/local/www/apache24/data/jpgraph-3.5.0b1/ttf/ in my browser
Then I have edit the jpg-config.inc.php and added the path
Uploaded the fonts to the ttf folder
The server says that it is unable to locate the JPGraph files when I try to get the rain_1hr.php
I run WDL 10.37R Build 81 on Win Xp and the files a uploaded to Freebsd 10.1
Please, command me dark lords…
graphsconf.php.txt (8.83 KB)
jpg-config.inc.php.txt (5.96 KB)
What is the full url are you using for rain_1hr.php?
I use the LAN…
http://192.168.100.100/wxgraphs/rain_1hr.php
And I have tried the FQDN too
http://www.schultze.nu/wxgraphs/rain_1hr.php
I think I got it to work.
I removed it all and started all over and this time unpack the tar files on the server. I also change the foder to just jpgraph instead of jpgraph-3.5.0b1
Found a small issue with wxgraphs (really a bug/issue with IIS).
I am using an IIS 7.5 server and apparently it does not like files names with a “+” symbol in them. They result in a 404 error.
So the following files do not work:
temp+dew+hum_1hr.php
temp+dew+hum_24hr.php
temp+hum_24hr.php
I noticed it in the Steel Gauges part of the Leuven-Template.
Changing the “+” symbol to a “_” and changing all references to those files makes everything work properly.
So anyone running an IIS server with php may also need to do the same.
I know this is an old post but I’ve been wanting to do something like this. Is this script still functional? If so on step 6, do I put the folder in the JGraphic folder of below it on the server? I’d appreciate any help.
Unless your server is already running php version 7 it should be fine.
- Create a new folder under jpgraph-x.xx called ttf.
/jpgraph-1.22/ttf/ (the numbers will be different for your version of jpgraph - I hope)
IOW you create the new ttf folder in your jpgraph-[version] folder.
MegaMaxPosts: 1
Future meterologist/storm chaser.
good to see a young weather enthusiast, welcome
Thank you to both of you.
I see this is a very old thread, but I’m following the instructions nonetheless to install.
I’ve tried everything I can think of but getting a repetitive error:
Strict Standards: strftime(): It is not safe to rely on the system’s timezone settings. You are required to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected ‘Europe/Berlin’ for ‘CEST/2.0/DST’ instead in /homepages/44/d119568937/htdocs/website/weather/jpgraph-4.0.1/src/jpgraph.php on line 395
e.g. http://www.hssc.net/weather/wxgraphs/windgust_1hr.php
And here are my PHP settings:
The warning is telling you to add a time zone setting line, like this:
date_default_timezone_set('Europe/London');
Be advised that a new version of JpGraph was released a few days ago (2016-08-09) - version 4.0.1 of JpGraph supports PHP5 (PHP 5.1.0 or higher version) and PHP 7.0.
Thanks R_o_b, good to know
Hi guys!
Yet another newbie with jpg-config.inc.php problems …
Hardpath is /customers/7/d/e/gudmundsbyn.se/httpd.www/jpgraph/truetype/ http://gudmundsbyn.se/jpgraph/truetype/hardpath.php
http://gudmundsbyn.se/jpgraph/truetype/arial.ttf and http://gudmundsbyn.se/jpgraph/truetype/arialbd.ttf exists and are readable.
I have tried http://gudmundsbyn.se/jpgraph/src/Examples/testsuit.php with:
define(‘TTF_DIR’,‘/jpgraph/truetype/’);
define(‘TTF_DIR’,‘/customers/7/d/e/gudmundsbyn.se/httpd.www/jpgraph/truetype/’);
define(‘TTF_DIR’,‘${WEBROOT}/jpgraph/truetype/’);
with no luck fonts are not working.
I hope one of you spots my mistake or has a good idea re what I can try to fix this …
Thanks in advance /JensB
