VP2 Solar readings
So my console and WD is showing readings from my solar sensor, but my icon wont change from overcast. I posted some screenshots. In the 1 screenshot, its showing “current average value 0%”, i,ve never really looked at that box before. Hopefully this helps. I can post more screen shots of my setup if needed.
Build 80
Did you change the settings to use a metar when your solar was down?
No, I just checked that incase.
This is strange. Im not using any 1-wire sensors anymore so I turned that off in the control panel. I just turned it back on and now my current condition icon is working. How is that possible since its not a 1-wire sensor?
if you were using a recent version then I would be able to debug this particular problem…
I’ll update again tomorrow. I was running build 307 and the same thing was happening.
