I have a few problems if anyone can help
- data from logger not uploading when i start WD.
- Temp line is stuck at 0.6, despite current temp showing -2.0
if anyone can help, i would appreciate this.
Keith
Keith
it could be that I do not have the data logger function working correctly in the Mac version
re 2:0
do you mean for live data?
one thing:
check to make sure that the minimum temperature limit under control panel,offsets…limits…is not set at 0
if it is, set that much lower
BRIAN
Keith
I am getting live data, on the display, but cannot see the live data from the logger window.
Temp offset was set to zero, noe set at -30, data has corrected itself.
Thank you.
one other question, can the battery voltage be displayed? have used the custom setting %batteryvolts% but nothing showing
the next update should get the battery working
Brian
downloaded and installed, battery V not showing.
keith
Brian
data still to being uploaded
Keith
Brian
Any update as to when the logger data will be sorted, so that it uploads?
Keith
its a bit confusing ,your posts
but I think you are refering to the data logger (history data for when WD was last running)
is not working currently
yes?
Brian
correct. when i open up WD, the historic data from the logger is not loaded.
sorry for the confusion.
Keith
Brian
di you ever receive the logger from Rianwise? and have you sorted the data download issues?
still trying to get a new main board at my end.
Keith
I did send them an email and they said they were still working on it
and would send it next week
but that was weeks ago
Brian
a new main board has been sourced for me, and should be shipped this week, so all will be working at my end again.
be good to get this sorted it think.
keith
Brian
i have a working weather station. Are you any closer to sorting out the issues connect to the logger as previously mentioned?
Keith
I have not heard any more from them
(and the data logger they said they would send weeks ago has not turned up)
Brian
that is of no surprise. would access to my machine help? each time i close down, i loose all my data.
Keith
how do you mean you loose all your data exactly?
Brian
when i open WD, the data from the logger is not loaded, hence i get gaps in the weather info.
keith
ah
the solution at this stage until I can get a data logger is to have WD run all the time
Brian
i had though of that, but not possible, still, the offer stands if you want oa access my Ma remotely as before.
Keith
we could try that then
ideally would be via a virtual com port connection
which version of WD are you running ?
