To All,
I’ve added the WD Webpage to my site and noticed the Weather Dials are so large you cannot see but a few. How do I fix it? Thanks
To All,
do you happen to be using windows set to large fonts?
you could also try:
setup, advanced/misc, main screen customisation and then click on reset weather dials
Brian,
I did what you said and still no change.
WD Version 10.37R297
OS Windows 10 Home Version 1511 Bld 10586.36
Checked text size and all are at a font of 9.
Change of size- under customize your display is set to 100%. Slider is all the way to the left.
if you could .zip and email me your settings files, I will test/check here
(see the FAQ on how to do that)
Brian,
I emailed you the information you requested. Thank you.
try
setup
full screen size…
click on no
then restart WD
Brian,
It is all working now.
I had to:
Thanks again for you assistance.
P.S. Where do I fix the temp in the dials screen to show DegF instead of DegC?
By the way. Where do you check the box to include the extradials.gif file?
I cannot seem to find it.
that looks like a bug re it showing C instead of F
I will fix that and let you know
re extra dials
if you go to view , extra dials…then tick to upload…
use a new .zip update re that F/C problem
Brian,
I do not see an extra dial button in the view screen. I just see Weather Dials, Wind Dials Only, Large Display and Floating Window.
right mouse click on the weather dials in the view panel
Got it. Thank you.
Brian,
I still cannot get the extra dials to load along with the Dials. The box is checked.
try the latest .zip update
as I see that the extra dials were not being saved
(when the normal weather dials are )
Extra Dials are now displaying. The only thing that I see is they all do not fit into the designed screen when displayed on the WD Webpage.
See attached.
I suspect you are not using the latest .zip update…try the latest .zip update
Can you tell me how to get the dials to animate?
Below is what I have. No animation on my website…
CI & File Creation
uploaded the latest update version-308 and now the control panel stops working after you open one of the options. I have to restart WD to get them working again.
when you say dials to animate…are you reffering to individual dial images…like gustdial.gif ?
also not sure what you mean by control panel stops working …can you provide more information on exactly what you are doing?
