Version 37.10Rb281 runs OK. Updated to v.301 and crashes after about 3 minutes. Attachment enclosed. Thanks Joe
programerrorlog.zip (381 Bytes)
try running this debug version
http://www.weather-display.com/downloadfiles/weatherdisplaydebug.zip
and see if an error report is created
I tried to run debug program but it says can’t start because PAKBUSDLL.DLL is missing? I did find the dll and ran the debug program. It still stops at about 106 data counts.
you would get that error if you tried to run it not from where
WD is installed already
do you happen to have wdwatchdig in use?
I will load a new download of WD different folder. No WDwatchdog in use.
not sure why you would be installing the debug .zip verison to a different folder?
I will try again I have been switching between version 10.37 81 and 13.37 301.
If I turn off the main internet switch off the program runs. When I turn it on the switch program run for a short time and then the Windows loading wheel starts running and the program stops.
After programs stops I get this message.
Stack overflow
Module: ntdll.dll
Code: C00000FD (EXCEPTION_STACK_OVERFLOW)
Address: 77AA2CC6 (00052CC6).
if you could .zip and email me your settings files, I will test here
(see the FAQ on how to do that)
how much memory does the pc have?
I am running with your settings OK Here …no crashes or errors
with the latest WD update
one thing: I see you are not using the FTP override, i.e the customise internet and file creation setup (which is recommended)
with that setup, you set WD to create which internet files you want and when and set to upload those when you want
(instead of all at the same time)…i.e you can spread them out
I would change to using that
Thanks Brain I will try again tomorrow. Joe
Problem RESOLVE thank to Brian’s hard work.
Glad everything is running OK
Thanks again Brian.
