Brian, tried a number of the blank dates I have showing. The files were created, but are essentially blank as far as data is concerned. Please see attachment (it’s the same for all I tried and for the full month - didn’t want to waste the space).
Trying to start with the oldest - 52006, 52007, 52008, then 62006, etc. There are NO lg.txt files for any of those, nor any of the others that are missing. Also, it’s not only the baro data (that link was just an example), but ALL Wx data for the blank items shown on that link - http://tiggrweather.net/wxbarosummary.php - temp, rain, wind, etc., etc. Use the WX Summary item on the nav bar to see any others. The same months/years are missing data.
Brian, really wish I knew. Over 5 years of recent good data, but that huge missing chunk early on. As mentioned, I remember having to get the data from WU day by day (they don’t offer getting a full month at a time, or at least not the last time I looked), then combining that into one monthly file, etc., etc. It’s the etc., etc., that I’ve forgotten how to do.
I am going to do that video next…
but I am thinking I could automate that process…in WD…in an added function…or even a separate .exe…which you would leave running to do its thing…good idea?
just to note that if you are using the function to fill in missing data for a month of data you have already, then its a bit more complicated
you would need to back up the existing logfile
then once you have done the import, slot in the new created logfile file (for that month) into the back up, where the missing data is, and then use action, convert WD logfiles to data files
Also in test.jpg the text overrun in the upper circled item (assume it’s the same data as in the lower circled item). However, after clicking the convert log to graph button that file is nowhere to be found.
it worked OK here with my metric wunderground data…but I have not tested with non metric data…
what is your wunderground ID …and I will test/check here
Using new WD I did another download (snip attached). Then did a convert log to data. That gave me 2 files - month62010.inf and month62010direction3.inf. Steps from here?
New download window is missing the convert buttons, etc. Has just the download area on the right side. Just for testing I suspect?
its all automatic
the conversion is done
thats why there is a .inf data file
you should see data after selecting that converted month under view ,av/ext
when I do it here, I get each day being downloaded and adding to the data in the window (which scrolls)
once that has finished you should have a logfile with all the data in it for the whole month
and that logfile us converted to data file at the end
there is a problem though where wunderground must use cookies…it downloads as metric for me (and so it works for me by ticking metric)
but it must be downloading as non metric for you
what I could do is add another function to convert that downloaded data (force a convert) (the wudownloaddata.txt file)
the other issue is irrregular time stamps periods in your wunderground data…not easy to pad it out to nice 1 minute interval
