Out here in Iowa, the land of Pollen, sneezing and ragweed. Pollen count is as important as other goodies.
I am using the Leuven Templates and things are fine. I want to add somewhere, either the script Pollen.com gave me or at least a link to their site. I have already used the two locations at the bottom of the menu script for other things, and I would like to add a tab on the menu for a url to that information or page.
I had sent an email to the author and I don’t think I was able to explain to him, (lost in the translation) exactly what I wanted to do. He suggested at the bottom of the main page perhaps I could add it there. I did turn off the banner option.
So… the question is can it be done, where can I put it there and how would I put either the script or the url to make it work without screwing the pooch so to speak on the whole site.
You can add as many as you like, even with an image or icon.
3. An image somewhere: If it is a small image you could add it as point 2, by setting the ‘icon’ => to the url of the image.
If it is a large complex image you could add it either as a separete page on its own or below other information, example below the AirQuality info.
As I am not familiar with the data pollen.com supplies, I can not help you with that. As I explained in your support request, I tried to find some info on their site but as far as I know they do not supply any data at all.
And to add pollen in the same way as ozone and the others, I need a script or an API description how to get the data using an xml or scraping the page.
The data should at least contain somthing like : " pollen level for today = 1 in the range from 0 - 5" .
But without that kind of data there is not much to add.
If this link is more or less or good enough for what you want, you could easily add it to any page, also below the AirQuality information in an iFrame. http://www.pollen.com/forecast_print.asp?zip=06511
But their is no data to scrape, so no way to add it to the AQ index, or on its own in a similar presentation.
Niko found the code, you now have to decide which of the two information blocks you want and were to place it. The links to click are three messages back,
is there any template that has snow depths. It isn’t snowing and probably with any luck I have 3 months until it becomes a concern, With WD I can enter them manually and they show up on WDL , so I was wondering if the would also show up on the current conditions page.
I think that would be in order, to add it to that AQ page.
