I keep receiving a warning alert email saying the minimum indoor temperature has been reached (which is set to 8 degrees) despite my indoor temperature never reaching that.
The temporary fix is that I have switched off this alert.
Anyone else seeing this?
This isn’t happening with any other thresholds or alerts.
Using Weather Display 10.37R build 281.
I am not seeing that. What you could do is go into the alerts (click on the flashing alert on the desktop) and switch off the offending item or increase the threshold to a much higher value, click OK and see if that works.
Another thing that causes flashing, is under the all time settings. If a new high temperature is reached, it will also flash there. Again, I would go into view, alltime and reset there. It might just be reporting a new high for you.
