I have tried to follow all the documentation and things I’ve read on the forums but I am lost! I have a registered copy of WDL and I am trying to use it on a Webpage template I down loaded from Leuven (2.7). The URL of my domain is www.txweathergeek.com. The best I can tell I have configured a few things correctly because the weather maps are correct. But the gauges are not correct and I get a flashing message that “the weather station is currently offline”. I don’t know, I guess, how to get in online?
I am using an Accurite 5 in 1 weather station which has been working fine. Can someone take a look and help guide to to a resolution? Much appreciated.
I moved your post here because it looks like you are requesting assistance to get the Leuven template working correctly at http://www.txweathergeek.com/weather27/
Guys I’m sorry. I accidentally deleted the template and decided to load the Saratoga template but I appear to be having the same issue in that I just can’t get the info from my weather page to show on the website?
It looks like you are not uploading anything to your site, have you turned the “Connections” from “FTP and Internet” on? you have to setup the FTP connection first. Then you have to turn on the real time ftp for the 10 sec. update.
Petros
I am getting the following when I click “Start” from the Real Time Upload page. I is asking for the password from my Cpanel?
Connecting to FTP server.
OK
Connected.
220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
220-You are user number 15 of 50 allowed.
220-Local time is now 14:03. Server port: 21.
220-This is a private system - No anonymous login
220-IPv6 connections are also welcome on this server.
220 You will be disconnected after 15 minutes of inactivity.
USER cecilsav
331 User cecilsav OK. Password required
PASSWORD=****
Connected.
220-You are user number 8 of 50 allowed.
220-Local time is now 14:16. Server port: 21.
USER cecilsav
PASSWORD=****
530 Login authentication failed
OK
Disconnected.
***141: [141] (no description available)
Reseting the FTP
The remote directory is wrong, how did you upload the files to your ftp? use the directory from the FTP client that you used to upload, something like /public_html/something or /https/something or whatever the path is
