I had been holding off mentioning this in the hope that it may have been related to the issue folks were having
with regards to the non responsive control panel issue, I have just tried B283 but that seemed worse…
The problem i have is WD becomes unresponsive every minute for at least 20+ seconds, this is down to using
Special File conversions, trends-inc, testtags and testtags2, heres the interesting part, it dont make any difference
if i remove one or all of the files to create, just have special file conversions turned on but not actually creating any
files still hurts WD for 20+ seconds, i have spent a good while tracking this down and like i said, B283 was no better
so therefore i am back on B271 as its only marginally better…
Just to sum up…
Having special file conversions turned on in internet and and file creations even WITHOUT any files to create cause the
extreme lag, this in turn causes WD to momentarily become unresponsive (in task manager) and cpu goes from 7 up to 25%
when using B283, cpu would hit 30%, hope this can shed a little more light on things…
testtags.txt has alot of tags in it to process
its not needed to be updated every minute,
instead set to every 10 minutes
as the web site uses the clientraw.txt file instead to get the live data
but I will see if I can find where the bottle necks are
Hi Brian, I am using the Leuven template, not sure if thats different, i never know how they work lol
So when you test on yours, are you saying wd’s clock only pauses for around 5 seconds?, mine is
about 20 - 25 seconds…
I have actually disabled a lot of stuff over the past few months too, so compared to what i do have
running now as a opposed when i was running Northants Weather, you could says its fairly minimalistic
CWOP, many graphs and graphics disabled, FB no longer working, no longer creating a database,
webcam removed.
I have testtags and testtags 2 and trends-inc running, not sure if i need trends-inc anymore mind but i have
kept it running just in case, i have tried each one of those three on their own to see which one might be causing the lag but each one on its own causes it to happen, the interesting part is it still does the lag
even if there is no files in the file creation setting to be run but still having that setting turned on, i.e. the
filenames left blank but still set (if that makes sense)
I wonder if its conflicting with something else that i have turned on in wd if its ok on your test machine?
Hi Brian, i can and will do that but, bear in mind that the issue still occurs when no files are added to the creation list, this points to it
not being a problem with the testtags or trends-inc…
did some experimenting here with new fresh settings only set to create the
testtags.txt
testtags2.txt
trends-inc.txt
to .php files
that you sent me
every minute
I notice your testtags.txt has the WebsterWeatherLive custom tags at the end (which is not what the original test tags has)
which adds alot more tags to be processes by WD
so that takes an extra second
and then the trends-inc.txt does not take very long
but the testtags2.txt file, which has another big lot of tags in it, that takes another second…so thats 6 seconds in total on my pc
build 81 took 6 seconds too…as a comparison…which means the latest version is working OK here in testing
have tested here with your settings…and changed to have the file #29 updated every minute…
this was completed in the 6 seconds , so similar to above test
(there is alot of custom tags to process in those 3 files)
Hi Brian, B81 is the same, although that took 28 seconds… i could understand it if i was on a slow machine but this is a AMD Phenom II X4 (Quad) 840 CPU 3.20 GHz with 4gb, C:/ has +140gb free too
Perhaps something else like a virus scanner is checking each file as it is updated by WD (log files, data files etc) and slowing down the process?
Or something to do with Win 10?
do you happen to use the web page search function Bashy?
(see in the FTP/internet setup)
as I have fixed one thing with that in the latest update that was causing lots of cpu use and a run away memory
Hi Brian, sorry for the late reply, been a bit hectic, YES, i do use the websearch feature, will have a go with the latest build now, thanks for letting me know
I dont use any virus proggy Martyn, only if i have a PC issue will i use one
Hi Brian, im on B293 and still the same for me, CPU goes up to around 29% and WD hangs for around 20 seconds
This only happens when the custom files are being created
Hi Brian, no difference, this machine now has 8gb to opposed to the previous 4gb, also when i was doing the testing before
i created this thread, it didnt make any difference if there was 1 file being created or all 3, i now just have it running every 10 mins
