Humidex in all time records
Hello…How do I get the Humidex to show in the Daily, Monthly and All time records? I see heat index but not humidex. Seems to me that if you choose to display and graph humidex instead of heat index it should show in the records as well.
Thanks!
I can change it so that , yes, if those are set, then it will be humidex instead of heat index
I will make that change for the next WD update (will not be retrospective though)
Thanks!
this should be working in the latest update :wink:
