I think this is a WD issue since WDL is fairly stable.
I have noticed in Build 282 (and before) that the output from Nexstorm is not being displayed when you click on the Lightning Button in WDL. I have not changed WDL version, so I think the file NEXTSTORM.txt, (Nexstorm.txt ) is the culprit.
I have attached 3 screenshot - on from the main nexstorm application, from the generic lightning button in WDL, and from the java Stormvue app. You can see the WDL is not correct. Also, the content of the NexTstorm.txt file in WD Webfiles directory, seems populated with data, and is on the Website and is being pointed to correctly in the WDLconfig.xml. The WDL screen looks like is sees the data in the supporting fields but is not able to display the strikes.
Craig
Edit - and with more 5000 lightning strikes, WD did not indicate “Thunder” in the significant conditions for the climate report…
