Wooden screen, replaced with a home-made plastic
Hi everybody
Quite some time ago I brought a wooden screen box, even though it Was well painted It Started to rot
I have some old offcuts of plastic called foam X , This plastic was easy to cut with a Stanley knife, The thickness of the material Is about 5 mm
I made a template from the old wooden screen, I’ve made it so it has three pieces of plastic Foam X material
Please see image, You can see the layering of the plastic white, black, white
There is a fan to draw air across the sensors
The instruments in this box,Going from left to right first instrument is a standard greenhouse minimum maximum temperature with manual reset
The next one is a small Thermometer that measures maximum temperature,
Next is the 1 wire wet bulb/dry bulb temperature sensors
The last one is a long yellow tubes which are wet and dry bulb Met office pattern Stevenson double shield
My outdoor temperature sensor, humidity sensor Are now housed in a Home-made separate screen unit, Will update my webpage soon on how I made this
